Blown Head Gasket
Old Jul 7, 2011 | 07:13 PM
gary pierce's Avatar
Default Blown Head Gasket
Well I put the re worked heads on and had 180 comp, set the timing as close as I could, cranked it up, and boom, water blew out in front of #1 cyl. The timing was really advanced so I turned the dist. and it runs perfect, no lifter noise, but smokes white out the pipe now. This is the first blown gasket I've ever encountered, so I guess I'll do it all over again.
Old Jul 7, 2011 | 07:19 PM
06murder's Avatar
make sure u line up them dow pins...
Old Jul 7, 2011 | 07:20 PM
Mangled03gmc's Avatar
Baltimore Whore
What is this on
Old Jul 7, 2011 | 07:22 PM
06murder's Avatar
sounds like a sbc?
Old Jul 7, 2011 | 07:43 PM
Sorry, its a 99 Tahoe 5.7, I also installed the new spider with 8 injectors and it sounds better than ever.
Old Jul 11, 2011 | 08:04 PM
I've got 150 to 170 comp in all cylinders, now do I pressurize the radiator and see if water comes out of a spark plug hole while turning over the motor? Anybody have any suggestions. I hate to pull the heads if its not them.
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
dantheman1540
Jul 29, 2015 04:45 PM
BIGD4504
Jul 28, 2015 11:46 AM
