Blown head gasket
Old Nov 14, 2004 | 04:24 PM
Flyer's Avatar
Default Blown head gasket
Check out this video of my exhaust on a cold start. Notice when it first starts how lumpy it sounds.
There's some coolant missing too ...
High Res (24.1 mb)
Low Res (7.6 mb)
Old Nov 14, 2004 | 04:47 PM
BigBlockChev572's Avatar
High Res (24.1 mb)
Low Res (7.6 mb)
Downloading vid now (dial-up, so I'm slow). The multi-layered Steel head gaskets seem ideal for boosted engines. You might want to pick some up.
Philip S.
Old Nov 14, 2004 | 05:55 PM
BlownChevy's Avatar
blownerator
25 Year Member
Can we say, blown head gasket.
Old Nov 14, 2004 | 05:59 PM
Flyer's Avatar
blown-head-gasket
I think I said it right.
Old Nov 14, 2004 | 06:00 PM
BlownChevy's Avatar
blownerator
25 Year Member
blown-head-gasket
yeah yeah.....I just listend to the vid.....I did not read the whole thing. YOu never have anything important to say anyhow
Old Nov 14, 2004 | 06:26 PM
parish8's Avatar
single digit dreamer
Philip S.
that motor should have came from the factory with mls gaskets in it. pushing 60lb's of air is a lot. how much boost/timing were you running? what compresion? what fuel?
it isn't too hard to swap them out in the truck, maybe you want to step up to some head studs while you are in there.
have you pulled the plugs yet? i would like to know what the worst one looks like.
Old Nov 14, 2004 | 06:29 PM
Sport Side's Avatar
I think you killed the **** outta that grass.
That sucks to hear man, now you gotta tear the whole thing apart
any plans, while your in there?
Old Nov 14, 2004 | 07:22 PM
James B.'s Avatar
Broken driveshaft, and now this? I think you need to have some one-on-one time with your truck man. Show some love.
Old Nov 14, 2004 | 07:40 PM
Flyer's Avatar
This happened I guess ever since I put the 6.0 heads on. I guess I'm gonna have to yank that one side off again. It won't be to big of a deal since I already got studs in there.
I don't have the coin at hte moment to do anything else with the heads. I have a set of 6.0 heads on there now.
I guess when I changed the pushrods (50 thou shorter), it started making more compression and went ahead and pushed them over the edge.
Old Nov 14, 2004 | 09:15 PM
2toneblown's Avatar
ARP studs and Cometic gaskets. Only way to go
