Blower or more juice.
Old Sep 11, 2004 | 07:03 PM
StupidFast's Avatar
Default Blower or more juice.
I am considering putting the blower back on.
I have 10.5:1 compression so the boost would have to stay low, 5lbs. Then spray 150 (with the direct port) top of that, using C16 in the fuel cell. Changing my camshaft to my old 216/220@114. The only thing I am worried about (besides my transmission ) is the cylinder pressures.
Would this be better than just pilling it up to a dual stage 250. Hitting a 150 at 3200 with the direct port and then spraying 100 with a single nozzle. Sticking with my current 230/230@112+4.
If it was your truck or car what would you do?
Old Sep 11, 2004 | 07:24 PM
greentahoe's Avatar
Even with a forged bottom end, that just seems like too much compression for boost. I would stick with N20, but you seem to be more knowledgable than I.
Old Sep 11, 2004 | 08:13 PM
GoldenVelvet's Avatar
What blower?
If you are running a non-intercooled blower like the old side mount magnacharger I would say more nitrous. If you have 10.5 now the hot air might be too much to justify the blower. But if you have an intercooled set up then there are more options. Like runming a very small dry shot through the intercooler would make an exponential return on power.
Old Sep 11, 2004 | 08:29 PM
redaddiction's Avatar
he has a procharger setup
Old Sep 11, 2004 | 08:43 PM
Arigom's Avatar
I would like the extra 75-100 hp that the blower gives you all the time. How often are you actually going to juice it. Plus it's free - 250 shot means you fill your bottle every 6 passes.
what is your ultimate HP goal?
How much is reliability a concern?
Could you pop in some forged slugs at around 9-9.5 compression?
How much of a daily driver is this - or how often are you gonna push it?
Old Sep 11, 2004 | 09:23 PM
I am not a genius, but I think more N20 would be safer. Unless you would consider lowering your compression somehow.
Old Sep 12, 2004 | 12:47 AM
Procharger would be really nice, but I agree that 10.5:1 isn't really ideal for a blower, but it should be fine for more spray. I would prefer to have the blower and spray on, but I think that you might be faster and safer with just more spray. I don't know for sure though.
I would probably put the blower back on if it were me, but mine is a daily driver and hasn't even seen the track yet. Yours is definately more of a track truck than mine.
Aaron
Old Sep 12, 2004 | 01:33 AM
PappyDan's Avatar
Tribe Shaman
at 9.0 to 1 you are good up to 9 psi on the blower, any more then you need to drop to 8.0 to 1 on comp, with winter comeing on soon and a comp of 10.5 to 1 i would run around 6 psi or less on the blower, should have you around 14.8 on comp almost 15 to 1.
calsdad
Jun 14, 2023 11:07 PM
bagged7104SS
Sep 24, 2015 08:42 PM
lxcoupe
Sep 22, 2015 02:50 PM
whippledstepside
Sep 17, 2015 05:02 AM
