Billet servo installation question
Installed a billet servo in my 2002 Silverado tonight. Instructions stated to grind tip of rod for 1/16 to 1/8 band adjustment clearance. Where do you determine this clearance or how? Or do you have to remove the pan?
Re: Billet servo installation question
Yep...gotta drop the pan. That is a step I had to perform with the install of the TransGo shift kit. The band is visible thru a gap in the valve body. I had to make sure the band would wiggle around a bit (high tech way of saying 1/16th to 1/8th inch clearance). If you need more details, send me an email at "sfranklin9@aol.com".
Scott
Scott
Jim, got it from www.kdsperformance.com ....$79+shipping, very tricky to remove and reinstall. The trick is to remove cover, remove e-clip and slide pistons off before trying to remove rod. Clearance is very limited between trans and tunnel. Goes back together the same way.
67SS509, glad you liked them. If you just take them out part by part you can do it. First time around it should take about two hours max.
Did you get just the intermediate or the overdrive too?
That clearance also changes shift timing...or when the band applies in reference to the forward/reverse clutches being released. Too tight and the band applies too early...too loose and it applies too late. But if its close, it should be fine.
My ATSG book says about 1/16"-1/8" and TransGo says 1/8"-1/4" (or maybe the other way around). So I figure somewhere between the 1/16" and 1/4" you should be fine.
I ordered the billet sevo and the OD servo from KDS,anything else recommended to extend the life of the 4L60e behind a S/C 5.3 4wd?
FlowmasterMufflers
07-17-2015 03:26 PM
