Biggest cam without a stall
Old Dec 12, 2006 | 08:03 PM
Coban's Avatar
Default Biggest cam without a stall
Whats the biggest cam anyone is running in an extended cab 5.3 2WD WITHOUT a stalled convertor??
I want personal experience, but I also what to know what you think I should do. I have a 212/218 hilift and I think its just great. I have 4.11s and they do help a lot. I don't really care about being able to spin the tires or off the line performance too much, but I want to be reasonable. I am looking at a TR220 on 114.
Old Dec 12, 2006 | 08:06 PM
TouchOfEvil04's Avatar
I have a 220 on a 112lsa in my 6.0 ecsb. I woudn't want to run it with a stock convertor. I have a 2600 and it does fine but ti's not in the cams real powerband. More like 3000-3200 which is why i am goin to put a 3200 stall in my truck soon.
Old Dec 12, 2006 | 08:14 PM
Coban's Avatar
But how bad is it really? Like could you feel it absolutely straining off the line or just couldn't spin the tires? Im not looking to be in the powerband 100% of the time.
Old Dec 12, 2006 | 08:16 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why not lts and exhaust first that would help alot with power.
Old Dec 12, 2006 | 08:19 PM
Ha, no it spins believe me it spins. It's just that once it hits 3000+ the power comes on and comes on hard.
If you want a stock stall why not get a Yank TT3000? I have a Yank TT2600 same line as the 3000.
I would have a 3000 but i bought the 2600 when i still had a stock cammed 5.3
Anyway the Yank TT2600&3000 feel like a stock stall convertor until you drop the hammer. You can still tow the same weight as stock still drives like stock.Just performs once you finally drop the hammer.
The 2600 does soso for me but with a stock stall only goin up to about 1800 or so like it would it's gonna feel really weak till about 3000plus. It just will leave a lack luster there if you keep it stock.
I would go Yank tt stall myself.
Old Dec 12, 2006 | 08:27 PM
Slowhawk's Avatar
LS1Tech Sponsor
I run a 216/222 Cam on my 5.3 ,stock converter,stock exhaust mani's/cats.Idles with alittle lope but no surging and drives like stock.Gained 40hp/20tq in 2nd gear pulls(have 3.42 gears)
Old Dec 12, 2006 | 08:34 PM
Coban's Avatar
I know headers and some kind of aftermarket exhaust would help a lot, cause I know its getting choked as it is. I just like to try something different.
I dont even want to think about a convertor until the tranny takes a ****. Im not going in there and putting the same tranny back.
Old Dec 12, 2006 | 08:36 PM
Coban's Avatar
This is the kinda thing I've been looking for. What grind is that btw? I know Vinci makes a 216/224, I think Thunder550 is even selling one.
Old Dec 12, 2006 | 08:38 PM
Moddoo's Avatar
Get some headers.
You're on the edge with your current cam.
It will be much better over 5000rpm with LTs & ORY.
Old Dec 12, 2006 | 08:51 PM
JJB's Avatar
JJB
Ihave definatly learned the hard way I put a large comp in one of my previous trucks and sounded grate but burned the verter up after 80 miles ,,,Hey Slowhawk those are great numbers from a cam only mod would you mind sharing your specs and or cam # I wouldnt mind putting tha cam in 06 4x4
James
