Biggest cam i can install into 4.8?!? HELP
Old Feb 26, 2007 | 10:28 PM
layindoors03's Avatar
Originally Posted by v8
You have pics of the intake on the truck??
intake wont help much, well the ls1, maybe the ls6, the 4.8 needs alot of stall like a 3600 and you will also need 4.10 gears to help the tq of the 4.8, also head work does wonders for the 4.8 or any engine that is.
look up 01thunder on the board he is runnning a 224 224 in his 4.8 with good results.
no no pictures yet i just have the intake setting on the motor for now, i did the itake for clearance issues because i bodydroped my truck but actually i bought the intake off of ebay and it didnt come with any intake bolts do you know where i can find them?? im having a hard time with that also..but thanks for all the info you guys have given me so far you rock!
Old Feb 27, 2007 | 10:41 AM
TXsilverado's Avatar
use the intake bolts from your stock manifold
Old Feb 27, 2007 | 10:54 AM
Mangled03gmc's Avatar
Baltimore Whore
Or go to the part numbers thread I beleive in this section and ask what the number is them guys are really good on getting the number 2 ya. Also you will need some tuning done for the cam to work..
John
Old Feb 27, 2007 | 02:18 PM
i tryed using the intake bolts from my stock intake manifold and they are to short it seems that i need longer ones for the LS1 intake...IDK
Old Feb 27, 2007 | 04:02 PM
dirt track racer 81's Avatar
the bolts are different..
go for the MS4 or the texas giant cam
Old Feb 27, 2007 | 10:11 PM
closet red neck's Avatar
I have a 110º sep in my truck. Look in sig. There is a sound clip, a couple of threads down if you want to hear one.
James
Old Feb 27, 2007 | 10:16 PM
Quik's Avatar
5 year bitches!
the chop and lope comes mostly from your amount of overlap a cam has not just LSA
to figure out overlap
take intake/exhaust duration and divide by 4
then subtract the lsa
then times it by 2
example
Trex
242/248 608/612 110
242+248=490/4=122.5-110=12.5*2=25 which is the amount of overlap the Trex has
Old Feb 27, 2007 | 10:28 PM
SSlow 4.8's Avatar
i'll get a sound clip of my truck for you when i get a chance if you'd like.. i havent actually got a clip of the new setup... but its a 224 on a 114 with gutted cats, as&m longtubes, and hooker aero chambers...
i'll do that for you ya tomorrow sometime
Old Feb 27, 2007 | 11:13 PM
yea bro that wuld be awesome!! you guys are a really big help because i wanted to put a cam in my truck a while back and i called this place i seen in the streettrucks mag. i think it was voodoo cams or something and he was like noo man tha 4.8 is way a small engine u cant put a cam in there its not gonna run right and blah blah..im glad i found u guys
Old Feb 28, 2007 | 08:22 AM
BlackPearlZ71's Avatar
you should get the 222/224...that one works great!! my friend has it on his 4.8 and is running a 13.4 all motor in mild weather and a 12.4 with nitrous....if i'm not mistaken he's the 2nd fastest 4.8 in the nation or around there.
