Biggest cam i can install into 4.8?!? HELP
Old Feb 26, 2007 | 04:44 PM
layindoors03's Avatar
Default Biggest cam i can install into 4.8?!? HELP
hey guys what is the biggest cam i can install into my 4.8 im not really worryed about the performance im just looking for the choppy sound i want it to cam when im setting at the redlight u know...please help thanks!
Old Feb 26, 2007 | 05:04 PM
Mangled03gmc's Avatar
Baltimore Whore
You don't need a big cam to get the chop, order something on a 110lsa and it will lope its *** off.. The tr220 0n a 112 will sound nice in a 4.8, there are alot more but that is a fairly popular choice..
John
Old Feb 26, 2007 | 05:15 PM
sweet where can i get it from is there a website or a phone number who makes the cam and is it like a whole kit ...where it comes with springs,cam or whatever i need..
Old Feb 26, 2007 | 05:18 PM
v8
17,16,15,14,13,12,11 Drvr
if you buy all new and have some one install it look at spending 1200 bucks for everything new and installed good luck
Now you can look in the parts forsale section and get everything for 600 installed, where ya from? you will also need a tune for the cam (depends on what you get)
good luck.
Old Feb 26, 2007 | 05:19 PM
v8
you could also pull one plug wire and get the same effect lol ahhaahahaa
Old Feb 26, 2007 | 05:42 PM
hahahhahaha dont wanna do the pull the plug wire trick...i heard a thunder 224/224 114lsa wuld be good and lope like i am looking for is this true?
Old Feb 26, 2007 | 06:12 PM
Baltimore Whore
That is who makes the tr220, but a 112lsa will have more lope then the 114. Check out thunder racing or texas speed, they have alot of good grinds for the trucks.. yes you can get a kit with springs, rods..
John
Old Feb 26, 2007 | 06:30 PM
sweet thanks bro im i will stick with the tr220/220 112lsa...what else wuld i need other than the cam...im sure i need a stall right? what size stall do i need to run and is there anything else i need to run to make it run good...im also running a LS1 intake if that makes a differece
Old Feb 26, 2007 | 08:10 PM
v8
You have pics of the intake on the truck??
intake wont help much, well the ls1, maybe the ls6, the 4.8 needs alot of stall like a 3600 and you will also need 4.10 gears to help the tq of the 4.8, also head work does wonders for the 4.8 or any engine that is.
look up 01thunder on the board he is runnning a 224 224 in his 4.8 with good results.
Old Feb 26, 2007 | 08:37 PM
TXsilverado's Avatar
look up 01 thunder. i love the way his truck idles. his is a 4.8 with a tr224 on a 112 lsa. either a 3500-3600 stall is what he's runnin. he has some sound clips here somewhere.
