Bigger tires = how much less go power?
Old Mar 5, 2004 | 03:26 PM
JayStew's Avatar
Default Bigger tires = how much less go power?
I've been thinking a little about getting some bigger tires (285/75/16) Stock is 265/75/16. What do you guys think I will lose if I do this?
Old Mar 5, 2004 | 03:42 PM
Flem's Avatar
you can roughly estimate the loss from the percentage increase in rolling diameter.
BurnOut's Avatar
265/75/16 is ~31.65" tall
285/75/16 is ~32.83" tall
The difference is roughly 4% (a little less, actually), so I would expect the difference to be similar to going to a 3.60 gear vs. a 3.73 (not that bad at all).
Old Mar 5, 2004 | 04:02 PM
BigTex's Avatar
You'll lose the gearing that you've just mentioned, then it will also take more power just to get the additional weight rolling.
When I went from 245.75.16s to 285.75.16s in my Z71, I lost about 8% gas mileage even after I adjusted the odometer for the larger tires.
Old Mar 5, 2004 | 04:30 PM
JayStew's Avatar
What about in the 1/4, .2 tenths maybe?
Old Mar 5, 2004 | 10:20 PM
F8L Z71's Avatar
Depends on how heavy your new tires are compared to the old ones.
My stock 265/75/16s weigh 54lbs. With 285/75/16 Wrangler ATs they weigh 66lbs. Thats 10lbs per rim for 40lbs total. 40lbs of weight on the wheels is "supposed" to be like 8lbs of dead weigh in the truck. Sooo 320lbs? That would kill ya by 2-3 10ths or so. If all the math is correct.
The above doesn't include loss due to diameter/gearing loss.
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
Sexyrado327
Aug 2, 2015 04:08 PM
Ketis
Jul 23, 2015 12:37 PM
