Big Block Swap???
Old Apr 24, 2007 | 04:38 PM
Sierra1320's Avatar
Default Big Block Swap???
Hey Guys,
I have a 2006 GMC Sierra RCSB 5.3L w/ 4L60E trans. I'm wondering if swapping in a BBC is possible. I know I'd have to modify the fuel system, cooling system, ignition system, exhaust system, but I'm wondering what else would be needed. Would I need to change engine mounts? Will the 4L60E bolt up to a BBC? Thanks Guys!
Old Apr 24, 2007 | 04:46 PM
nightrunner's Avatar
Mr. Obvious
im gonna be the first to ask WHY?
it certaintly isnt for fuel mileage or power...
Old Apr 24, 2007 | 04:47 PM
LesPaul's Avatar
If it was me.... and i was going to go through all that trouble... i would make it a big Pain.... Why not put a D-max in it
Old Apr 24, 2007 | 05:01 PM
thunder550's Avatar
High on diesel fumes
BBC isn't worth it IMO...if you're going to big cubes go with a well-built 408 that will drop right in. All you'd have to change it the tune. And probably the tranny, I doubt the 60E would hold up for long. You'll get just as much (if not more) power, and better mileage.
Old Apr 24, 2007 | 05:05 PM
LesPaul's Avatar
i just cant believe we are actually saying the word mileage in the same breath as 408 and big block.... and truck for that matter
Old Apr 24, 2007 | 05:21 PM
thunder550's Avatar
Mileage, you know....gallons per mile....
Old Apr 24, 2007 | 05:36 PM
Mr. Obvious
the only thing i can see it for is a show truck or bragging rights
unless you want monster power and torque in a NA motor as in 650rwhp(540BBC), but then again your could just a build up a LSX block and have that much power or more
Old Apr 24, 2007 | 06:56 PM
Leroy_454's Avatar
Why do such a slice job on a basically new truck. Go with a LQ4 or LQ9 6.0L with a cam, tuning, stall converter/trans. mods, and other supporting bolt-ons. You would probably forget about that BBC quick.
Old Apr 24, 2007 | 06:58 PM
dirt track racer 81's Avatar
Old Apr 25, 2007 | 12:42 AM
Quik's Avatar
5 year bitches!
look into the 01 with the HD conversion. that guy put a 8.1 BBC in it. he used two trucks. a HD frame and a 1500 frame to drop the 496 down in it
but like others said its pointless. you can get 427 factory cubic inchs with small block lsx
