better performance
Old Oct 6, 2005 | 03:29 PM
Default better performance
what would give you better performance the stock truck intake or a ls6 corvette intake.
Old Oct 6, 2005 | 03:33 PM
Fogle07's Avatar
from what i understand a ls6 intake actually hurts performance on trucks. not 100% sure about this though. you can try searching for it. i know people have discussed this in the past.
Old Oct 6, 2005 | 03:34 PM
you have a very sharp truck
Old Oct 6, 2005 | 03:39 PM
budhayes3's Avatar
PT's Slowest Truck
I think that with the LS6 intake it will hurt down low but flow better up top. If you have money to burn and you plan on building a high revving top end screamer, you can get the FAST intake, along with modifying the water pump, swapping in efans, and modifying the accessories to allow clearance for it.
*EDIT* I should have read your sig first...I see you already have an LS1 intake, so you should already have fixed the clearance issues.
Old Oct 6, 2005 | 03:41 PM
Gran Patron's Avatar
I heard it doesnt do any good! The stock intakes provide more Torque and the LS6 intake really wont provide any performance gains. But yes try doing a search on it, it's been discussed before and you'll find why it dont help.
Old Oct 6, 2005 | 03:42 PM
Fogle07's Avatar
thanks i really appreciate it. i got a LS1 intake if you want i dont know if it would work on a truck or not. i think it will only work on 5.7s
Old Oct 6, 2005 | 03:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Truck intake is better it gives you the performance down low where you need it to get the heavy *** truck moving.
Old Oct 6, 2005 | 11:09 PM
YenkoST's Avatar
I've read the truck intake gives better low and mid range hp and tq where the LS6 helps up top the most...CHP magazine did a comparison of the truck intake, LS6, LS1, and Fast in one of the magazines with different cam setups to prove my statement.
mikeyjm1
17
Oct 29, 2015 11:04 PM
gaps
Oct 15, 2015 02:53 PM
gavin2005
Sep 13, 2015 09:04 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
montecarloss
Sep 2, 2015 04:44 PM
