Best setup for a ECSB
Old Aug 9, 2008 | 12:04 PM
00ChevyScott's Avatar
Wearin' da big hat
Default Best setup for a ECSB
I'm currently saving up for a built tranny and stall, but I am trying to figure out if a gear swap would be beneficial to me.
Would I be better off going with a 3200-3400 stall and keeping my 3.42s?
or should I go with a 3000 stall and 4.10s.
I also plan on putting a truetrac later when I can afford it, so I could do the gear swap then, if it will help.
Old Aug 9, 2008 | 12:54 PM
mcfarlnd's Avatar
Un-Registered User
i enjoy my 3000 with 3.73s.
Old Aug 9, 2008 | 12:56 PM
L7 Sierra's Avatar
Depends on the purpose for which your building, and tire diameter. A high stall converter will heat up a tranny big time, and with a torque motor like most LS's are is not always the best thing. I personally did not use anymore the 2400 stall in any of my hot rods to keep driveability higher, and I like to gear a vehicle as much as posible. With our overdrive, 30 tall tires, and a motor that likes reving 4.11's are always a better choice.
As I get more money for my truck becouse I have more pressing issues, drivetrain wise I will probily go to 4.11's atleast but probily 4.56's since my gas mileage difference between drive and overdrive is none existant.
My 3.23 gears in drive roughly equal 4.56 in over drive.
Since my truck is going to be my shop truck for my buisness I will not put a stall in it becouse of the weight I will be hauling, but if I keep on just doing side work I will probily go for a 2200rpm stall. Then I might have a burn out machine.
chevyguy7802's Avatar
Id go with the 3200 w/ the 4.10's..........
Old Aug 9, 2008 | 01:39 PM
Wearin' da big hat
Since when was a 5.3 a torque motor? These motors have no ***** below 3,000 rpms.
Old Aug 9, 2008 | 01:49 PM
dirt track racer 81's Avatar
3200 and 4.10s get a 40,000gvw cooler and be just fine..i towed my race car to the track several times
Old Aug 9, 2008 | 04:54 PM
joeyc125's Avatar
11 Second Truck Club
Choda
Jun 5, 2025 06:43 PM
simman22
Jan 21, 2017 10:27 PM
Closer_2001
Sep 16, 2015 11:46 AM
hutch311
Sep 13, 2015 02:52 PM
dhorner77
Sep 11, 2015 05:10 PM
