Best MAF to run
Old Oct 27, 2006 | 09:57 PM
thunder550's Avatar
High on diesel fumes
Default Best MAF to run
Probably going to put a MAF back in my truck, but I sold my stocker. What should I go with? Another stock truck MAF? I think I remember hearing something about GTO MAF's being bigger? Aftermarket?
Old Oct 27, 2006 | 10:01 PM
Bowtie70SS's Avatar
What happened to the SD tune? Was it not working out? Reason I ask is because I am considering a SD tune for my radix'd 03 SS. Just curious is all. I would think you could pick up a stock MAF for cheap around here.
Dave
Old Oct 28, 2006 | 09:16 AM
nightrunner's Avatar
Mr. Obvious
now that i think about it the gto (or any ls2) maf should be 90mm since the tb is 90mm...
Old Oct 28, 2006 | 10:50 AM
dirt track racer 81's Avatar
your stupid goin back to the maf
Old Oct 28, 2006 | 12:50 PM
theres no point to get a MAF thats bigger than your throttle body, id say just get whatevers cheapest
Old Oct 28, 2006 | 03:09 PM
Bowtie70SS's Avatar
In his sig there is a Nick Williams 90mm throttle body.
Dave
Old Oct 28, 2006 | 03:47 PM
i stand owned
Old Oct 28, 2006 | 09:44 PM
thunder550's Avatar
Dave
Trying to correct lean tip-in condition when I go into boost. I've been told that I can still run a 2 bar tune with a MAF, so I want to try it and see what happens.
Do you know if they are plug and play?
Old Oct 28, 2006 | 10:03 PM
dewmanshu's Avatar
Moderately Differentiated
hey thunder, justin is having issues with his setup i do believe. Have you got confirmation from efi that your os supports it?
Old Oct 28, 2006 | 10:04 PM
thunder550's Avatar
Yeah, kbracing96 is running the same setup I'm talking about running
https://ls1tech.com/forums/showthread.php?t=599206
