Best LOW-MID torque cam
Old Sep 29, 2008 | 03:01 PM
  #31
Originally Posted by StrokerAce03
I wouldn't consider any of those lopey; lsa plays a small part in the lope. Most all lope is in the overlap. The lsa will determine the powerband more than anything.
That being said; the Vinci ultra torque cam would be a great choice. Its a 210/218 .551 with an lsa choice of anywhere from 112 to 116. Bud's 206/212 would be a damn good one too. Acutally I just pretty much restated Bud's post
The vinci ultra torque is a Z06 cam, basically and i dont want that.
Im trying to stick with the lower duration, and higher lift.
So, does anyone know if the specs I listed are possible?
Old Sep 29, 2008 | 04:09 PM
  #32
Moddoo's Avatar
Anything is possible.
Look to Comps XFI lobes for short duration, high lift.
Old Sep 29, 2008 | 07:02 PM
  #33
dirt track racer 81's Avatar
i pulled 12k lbs with my ecsb with a comp 212 218 .522 .529 114 lsa.. i had no problems with it..even pulled it with a tr224 just fine..the 212 218 was fun to play around the street with. even on a stock converter it took off harder than the stock cam..oh well just my opinion.. keep kickin a dead horse untill you have to order a custom ground cam or go with what moddoo said with comps low duration high lift cams
Old Sep 29, 2008 | 07:21 PM
  #34
StrokerAce03's Avatar
Z06 = 207/217 @ .050" .525/.525 on a 116 LSA
Vinci = 210/218 @ .050" .551/.551 on a 112/114/116 LSA
If you don't want that much then I'll go back to what BudHayes3 said and recommend the 206/212 Comp; I'm sure you can get it custom ground with higher lift. PM Patrick G. on ls1tech and he'll spec you a cam that'll be perfect.
Old Sep 29, 2008 | 08:30 PM
  #35
blueflamed03's Avatar
what about...
http://www.compcams.com/Cam_Specs/Ca...csid=1095&sb=2
Old Sep 30, 2008 | 02:27 PM
  #36
Talked to Patrick, and he can make a cam like I want...woot!
THe specs I gave him will make a helluva low-mid torque cam...just want I want!
Old Sep 30, 2008 | 04:39 PM
  #37
budhayes3's Avatar
PT's Slowest Truck
What are the specs??
Old Sep 30, 2008 | 06:43 PM
  #38
SlvrSierra4.8's Avatar
WERD?
Old Sep 30, 2008 | 11:44 PM
  #39
lols...
its a super low duration, and a really big lift.
I thought my combo was un-doable, but he said he can!
Old Oct 1, 2008 | 12:12 AM
  #40
lols...
specs? what's up w/ the secretive cam specs?
