Best LOW-MID torque cam
#31
I wouldn't consider any of those lopey; lsa plays a small part in the lope. Most all lope is in the overlap. The lsa will determine the powerband more than anything.
That being said; the Vinci ultra torque cam would be a great choice. Its a 210/218 .551 with an lsa choice of anywhere from 112 to 116. Bud's 206/212 would be a damn good one too. Acutally I just pretty much restated Bud's post
Im trying to stick with the lower duration, and higher lift.
So, does anyone know if the specs I listed are possible?
#33
i pulled 12k lbs with my ecsb with a comp 212 218 .522 .529 114 lsa.. i had no problems with it..even pulled it with a tr224 just fine..the 212 218 was fun to play around the street with. even on a stock converter it took off harder than the stock cam..oh well just my opinion.. keep kickin a dead horse untill you have to order a custom ground cam or go with what moddoo said with comps low duration high lift cams
#34
Vinci = 210/218 @ .050" .551/.551 on a 112/114/116 LSA
If you don't want that much then I'll go back to what BudHayes3 said and recommend the 206/212 Comp; I'm sure you can get it custom ground with higher lift. PM Patrick G. on ls1tech and he'll spec you a cam that'll be perfect.
#35
#37
#40
