Best dd cam for 07 silverado?
Old 09-30-2009, 12:26 AM
Registered User
albayfz450's Avatar
Default Best dd cam for 07 silverado?
What would be a good daily driver cam with a sick idle? Whats the average hp gain with it? Ive searched in different places but cant seem to find anything. thanks
Forgot to add that its a 5.3 NNBS ext cab if that matters
Last edited by albayfz450; 09-30-2009 at 12:28 AM. Reason: Forgot to add that its a 5.3 NNBS ext cab if that matters
Old 09-30-2009, 12:33 AM
Formerly darynC-10/23/10
Daryn's Avatar
any 224/224 on a 112lsa is about the max u can put on a stock converter
u will need headers, intake ,pushrods, upgraded ,valve, springs and someone to tune it.
Old 09-30-2009, 12:45 AM
Registered User
albayfz450's Avatar
Im going to put a tb tc and lt headers and a better intake. as of now i have a 10 series flowmaster and a black bear tune
Old 09-30-2009, 02:39 AM
Banned
lucky77's Avatar
212/218 - 56X lift - 112- 114+ lsa, good for bottond end.. easy on the gas..
Old 10-03-2009, 03:19 PM
zachm89's Avatar
212/218 with a 112lsa is a good DD cam with a "choppy" idle. and like dayrn c said you will need to upgrade your springs, pushrods and even lifters would be a good idea, as well as headers and an intake. Instead of a TB converter id spend a little extra $$ and get something with a 2800-3200 stall.
Old 10-03-2009, 11:55 PM
Registered User
albayfz450's Avatar
I was looking at the 220 and the 224 cams. Are those any good?
Old 10-04-2009, 12:09 AM
pewterliftedz's Avatar
the only problem with going for something in the 220 or 224 range is that your going to need a converter to run them well...
vinci has a 210/218 551/551 on a 112.
it will make a choppy idle and make power from 1900 up...
remember that a tbtc will only flash to about 2500 behind a 5.3..
Old 10-04-2009, 12:30 AM
Where's the Beef?
viciousknid's Avatar
with HUNDREDS of cam threads how can you not find anything? They all say the same thing that this one is already saying.
My cam is a 216/220 114lsa and it has a noticeable idle. With the 3000 stall it feels good but still isn't quite in the sweet spot.
If you don't want to change converters you won't want a 220, Unless you don't mind losing low end. meaning it will feel slow until you hit about 3500rpm and it will all the sudden take off.
If you don't mind changing the converter then by all means get one but make sure you get about 3400 or so to make it feel right.
I'd Recommend Circle D for a converter because they are tighter than most and that helps your MPGs in city driving.
Old 10-04-2009, 02:22 AM
SPAM HUNTER
2005 Silverado's Avatar
Texas Giant, or MS4
Dustin
Old 10-04-2009, 02:26 AM
Originally Posted by 2005 Silverado
Texas Giant, or MS4
Dustin
any of the smaller comp cams are good like the 212/218 low lift.
Quick Reply: Best dd cam for 07 silverado?
