best conv. for a whipple?
Old May 5, 2003 | 11:09 PM
454SuperSport's Avatar
Default best conv. for a whipple?
what seems to be the favorite converter for the whipple? i was leaning towards the yank tt3000, but have been changing my mind alot lately. the trans is due for a rebuild in the next couple of weeks and i was going to swap converters while it was out. this is the setup i will be running when the conv. goes in: 2001 scsb 5.3 3.73's w/g80, airaid box, whipple kit, custom predator tune, jba headers/ no cats/ 2.5" true duals w/ x pipe and dual magnaflows, e fans. the truck is my daily driver and only sees the track about once every month. i never plan on buying slicks so it will always be on 285/50/18 yokohama avs s/t's. what do you guys think?
Old May 6, 2003 | 04:41 PM
parish8's Avatar
single digit dreamer
Default Re: best conv. for a whipple?
i have the tt3000, it is a great converter with the whipple, might have a hard time hooking up without some sticky tires though.
Old May 6, 2003 | 05:00 PM
alright, let me explain myself alittle better. i do drive the truck every day and it only goes to the track every now and then but i like to drive hard. i want something that will launch hard and pull hard but still be pretty streetable for when i take the girl out. i don't want to have to worry about the trans getting to hot or anything like that either. i think parish8's going to talk me into the tt3000 because thats what i was originally going for. parish, how do you like the converters street manners? do you think i could still hook with street tires as long as i didn't stomp it off the line? does it pull harder in the powerband w/ the converter (higher STR)?
Old May 6, 2003 | 05:26 PM
parish8's Avatar
everyone here will tell you the street mannors are exelent, after a couple of days you will forget it is there but when you floor it the tires will fry , with some wide tires you will be able to modulate it and get moving prety well i would think. i let anyone borrow my truck and dont tell them anything, no one has ever made a comment on it, it is that mild but when you floor it it is great. if you tow with it a cooler might be a good idea.
i gaurentee you will be nithing but if you get one.
i really can't say if it is the best converter for you, this is the only converter i have ever had but i can tell say you will like it and not find it dificult to get used to.
Old May 6, 2003 | 05:33 PM
BigKID's Avatar
My yank goes in next week and I will let you know how it does with the Yokos. I really cant see how you hook up now on them with the Whipple. I can roast mine pretty good on a hard launch on motor and I cant even think about spraying out the hole on them. So it ought to be fun learning how to launch again with the Yank.
Old May 6, 2003 | 05:55 PM
they wouldn't hook for crap the first day the blower went on. it would fry them through first and second from a dead stop and ~20mph roll. now i can stomp it from a dead stop and they won't even chirp, thats how bad the tranny is slippin. i went to the track sat. night and cut the below time w/ the wasted trans so i know it will run pretty strong. one run it hit the rev limiter on the 1-2 and still ran a 14.52@96ish. should have shifted @ 5600 . think its time for a rebuild? haha
Old May 6, 2003 | 07:59 PM
1999stepside's Avatar
I am a fan of PI Vig 3200
Kent
Lthompson
Oct 2, 2015 12:45 AM
lxcoupe
Sep 22, 2015 02:50 PM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
MS3Z
Jul 30, 2015 06:17 PM
