Benefits of LS6 ported oil pump and double roller timing chain?
Old Feb 21, 2004 | 06:32 PM
Lightbulb Benefits of LS6 ported oil pump and double roller timing chain?
OK, I know the double roller timing chain/gears are tougher than nails and practically bulletproof, but what are the other benefits that one might gain from installing it and a Ported LS6 oil pump when foing a cam swap? I only have abou 27K so I don't really NEED to change either..I'm just trying to figure out if I should go ahead and save up the $ and get those two items and change them when I do the cam swap. The drawback is I'd have to wait to do it all at once until I got the bread for the pump and chain...but if the positives outweigh a little money and waiting on the swap, then that's what I'll do!
Thanks fellas!
Old Feb 21, 2004 | 08:30 PM
To me it was piece of mind. Although many have pumped some serious hp using the stock chain, personally I didn't like the slop in it when I put in my first cam. If you've ever opened the timing cover before you know what I mean. The rollmaster double chain I put in, has nearly 0 play. Just enough for you to work with it, that's it. Since I was going to have to get that off, I also replaced the pump over to the ported LS6. Again, just piece of mind. Do they make a diff in the whole scheme of things? Maybe, maybe not. It's kind of like putting in better pushrods - piece of mind.
I got the chain from SDPC and the pump from Thunder Racing. Both ran about $210. Worth it to me.
Old Feb 21, 2004 | 09:55 PM
I would replace the chain, but I wouldn't go to the trouble of doing a double chain. I have a Rollmaster on my T/A, going with a single JWIS chain on the truck. I kept the stock oil pump on the T/A, but I have a TR modified pump for the truck.
Old Feb 22, 2004 | 09:41 PM
JWIS chain is about double the price and both are just as easy to replace.
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
The_W
Oct 28, 2015 09:00 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
