Belt slip on P1sc--Need help
Old Jun 10, 2005 | 08:33 PM
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by Calbo
Looks like there is no alignment problem and no coolant leak. My buddy says I should probably go to an 8-rib. I'm thinking try an old school tensioner first. ( cost)
Texas Terminator- will that Katech tensioner bolt up to my 5.3 ? Why does GM put a spring tensioner on trucks and "old school" tensioners on the aluminium engines in cars? If I crank on the belt to stop the compressor slipping will bearing/shaft life be less on the acessories?
GM puts spring tensioners on the aluminum engined cars also. It is a better design for belt and accessory life in a stock app. It may not provide enough tension though to keep the belt from slipping on a supercharger that requires alot of power to spin.
Old Jun 11, 2005 | 05:04 PM
Calbo's Avatar
I thought that they used manual tensioners on the cars. Thinking again
I am going to try the katech tensioner. Will it shorten my belt and acessory life and by how much?
Old Jun 11, 2005 | 05:11 PM
lm7's Avatar
lm7
thats a big 10-4 on the spring tensioners for the cars.
Old Jun 11, 2005 | 05:35 PM
XLR8NSS's Avatar
Adkoonerstrator
Ok, maybe a bit of confusion on what we're both talking about.
GM uses an auto tensioner on the serpentine belt on both the cars and trucks. I have a car and truck to look at so I know this to be a fact.
ATI uses a manual tensioner setup on the Procharger setups for the cars. The procharger on the cars runs on it's own belt, not the serpentine belt that drives the rest of the accessories like the truck setup. It is a really bad setup and belt slip is a big problem on the cars. There is a spring loaded setup for the procharger car setups that really helps control belt slip very well.
I think a spring tensioner is the way to go but, the stock GM tensioner probably just doesn't have enough tension to keep the belt from slipping on the supercharger. With the manual tensioner you should be able to crank it down pretty good.
I really can't answer the belt and accessory life question with a manual tensioner. It probably doesn't help but, I don't think I've ever heard of anyone wiping out bearings after installing one.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Vortec350ss
Jan 12, 2016 10:36 PM
Gadgetized
Oct 22, 2015 09:06 AM
Chevy305
Sep 28, 2015 09:21 PM
murderedSS
Sep 27, 2015 10:16 PM
