before and after TBSS INTAKE dyno finally
Old Sep 20, 2010 | 08:29 AM
  #111
BlackGMC's Avatar
Resident Retard
I just finished up this swap on my 04. The gains are noticeable across the entire power band and really noticeable above 4k.
Old Sep 21, 2010 | 12:08 AM
  #112
Area47's Avatar
wonder if this would do anything on a 6.2
Old Sep 21, 2010 | 06:14 AM
  #113
03_Denali's Avatar
a 6.2 already has a 90mm tb. So the answer is "nope". You could probably pull the intake and have it ported. That would probably pick up some power. Idk, maybe someone that has done it could chime in...
Old Sep 21, 2010 | 06:28 AM
  #114
Tootall's Avatar
you could put the FAST LSXR on it, but your intake already has the square intake ports on it
Old Sep 21, 2010 | 01:20 PM
  #115
06FASTLQ9's Avatar
So is the TBSS intake manifold tha same as the 07 and up manifolds?
Old Sep 21, 2010 | 10:31 PM
  #116
skolman91's Avatar
read this thread quite a bit but dont think ive seen the answer to my question for sure. are the evap connectors the same for each style intake evap solenoid?
Old Sep 21, 2010 | 10:43 PM
  #117
LS1FREEK's Avatar
13 Second Truck Club
Very Impressive, now I really want one of them intakes for my LQ4
Old Sep 26, 2010 | 12:56 PM
  #118
greenturtle05's Avatar
Originally Posted by Tootall
use your current stock fuel rails, or use the ones that came with the intake. You can use return or return-less . . .
If you get the aftermarket rails, you'll have to fab your own mounts to the intake.
I did the swap on my 04, it's already a return-less fuel rail. I just reused the fuel rail that it came with, Dr X harness, and the truck TB. I did not need to get any extention harness for the MAP sensor, just open up all of the electrical tape, move it to where you want it, and then tape it back up. There's plenty of wiring already there, there was no cutting at all.
Which TB did you use? isn't the truck TB a 3 bolt and the tbss intake is 4?
Old Sep 26, 2010 | 01:08 PM
  #119
02'Z71ONDUBZ''s Avatar
He's talking about the 07-up throttle body that comes with these intakes on NNBS trucks. It's an 87mm 4 bolt. The Dr. X harness makes it a plug and play job.
Old Sep 26, 2010 | 11:42 PM
  #120
Same question??
