bbc conversion
Old Mar 14, 2009 | 11:57 AM
duke1's Avatar
Registered User
Question bbc conversion
hello gentlemen i have a worn out 1993 c-1500 that im starting to restore
and i am wanting to do something like a 454 ss conversion from the small block that is in it now can anyone give me some advice and do and donts
on this i think a 454ss ext cab would be neat what am i going to have to change i e ecu tbi trans
thanks for any help on this
Duke
Old Mar 14, 2009 | 12:16 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like a nice project, make sure you have a strong trans and rear backing up that big block Are you going to rebuild a 454, or get a crate engine or what? How about a 572
Oh, and welcome to PT.net
Old Mar 14, 2009 | 12:20 PM
12sec.5.3's Avatar
Sounds like it will be a fun project. Did you think about putting a ls engine in it?
Old Mar 14, 2009 | 12:40 PM
budhayes3's Avatar
PT's Slowest Truck
I like the sounds of that
Old Mar 14, 2009 | 02:48 PM
duke1's Avatar
Registered User
Default im gonna build it
i am going to build my big block i am a machinist by trade so i am gonna play with it and see what happens i have a fresh 4l80e with a shift kit and a vette
survo and 2500 stall so im gonna out a warm little roller cam in it and see what happens next
Old Mar 15, 2009 | 12:45 AM
budhayes3's Avatar
PT's Slowest Truck
Sounds like a nice build...I'm not too familiar with non GENIII engine swaps but I'll give you a bump to the top so maybe one of our experts might see this and chime in. I wonder if the newer 8.1 parts (intake, harness, PCM, etc) will bolt up and can be tuned for ya?
Old Mar 15, 2009 | 01:22 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The programing is different between an SBC and a BBC. Same with the Transmission I would find a similar year 2500 with a 454 and pull the engine wiring harness and ECU. By the time you try to re-wire what you have, You will wonder why you didnt just pull a factory harness thats already set up for it... If you go to a local do it yourself wrecking yard I am sure you can get a wiring harness with the Ecu for less then $100...
Old Mar 15, 2009 | 08:50 PM
how do you have a vette servo in a 4l80e ?
dantheman1540
Nov 1, 2015 02:59 AM
Silver8ado
Sep 30, 2015 11:42 AM
Frizzle53
Sep 13, 2015 12:32 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
