Battery light on after engine swap (not the alt)
Old Jan 22, 2011 | 02:58 PM
Cook's Avatar
Default Battery light on after engine swap (not the alt)
So I swapped from a 4.3L V6 to a 5.3L V8 on my 2003 Silverado 1500. I have the following codes on:
p0315 - crank relearn
p0178 - fuel composition sensor (my truck isnt e85 but the computer must think it is)
p0480/481 - efans
my battery light is on but im getting 14 volts. I checked all the wiring and I have 1 ohm from the batt to the alt, batt to frame, frame to motor, and motor to batt. I did the big 3 upgrade and also tried a new 105 amp alternator with no success. it left me thinking that the truck was calling for a 145 amp alternator, so i went out and got one. still no success.
any suggestions? for some reason i dont think its tuning related
Old Jan 22, 2011 | 03:09 PM
TIM Z's Avatar
11 sec. Truck Mod
I wish i knew, Since i started modding my truck and altering the tuning, ive had the damn battery display in my message center flash on and off. VERY annoying!!!
Old Jan 22, 2011 | 07:48 PM
Cook's Avatar
yeah its certainly odd
Old Jan 22, 2011 | 08:34 PM
skeet's Avatar
i had this issue before and for the life of me i couldnt figure it out, so i had an extra ecm so i just wrote my tune to it and solved the battery light issue..
not saying this will solve yours just saying it did solve mine..
Old Jan 22, 2011 | 09:31 PM
Cook's Avatar
thanks for the info skeet
Old Jan 23, 2011 | 07:57 AM
TIM Z's Avatar
11 sec. Truck Mod
I have 2 PCMs and both do it. Wander if i can delete it in EFI Live? I'll have to look.
Old Jan 23, 2011 | 08:22 AM
Cook's Avatar
Let me know what you find
Old Jan 24, 2011 | 01:38 AM
Blown06's Avatar
8 Second Truck Club
If its a swap, how did you wire the plug that comes off the alternator. I'm dealing with that now trying to make a custom engine harness.
Old Jan 24, 2011 | 05:15 AM
Cook's Avatar
i just used a stock v8 harness
Old Jan 26, 2011 | 08:32 PM
joeyc125's Avatar
11 Second Truck Club
I just went in my dtc's and turned off generator L terminal, and generator F terminal to no error reported. Solved my problem, no bright blinking red battery anymore.
