basic wire up for fans
Old Jul 8, 2010 | 11:29 PM
Sinistersilverado's Avatar
Default basic wire up for fans
i've been wanting to put electric fans on my truck, but keep getting told i need a relay? well i can care less if the fans turn on by themself. i mean i want to be able to just wire them up to a toggle switch and have them on when "i" flip the switch. Can't i just wire them up to a toggle switch as if they were fog lamps? Also how can i get off the factory fan without using the fan tool? seems no one here in this town has what i'm requiring.
Old Jul 8, 2010 | 11:36 PM
BlackGMC's Avatar
Resident Retard
you run the risk and high probability of melting the switch due to the high current draw of the fans... This is where a relay comes in, it helps prevent switch melting...
Old Jul 8, 2010 | 11:39 PM
neilownz's Avatar
Sure, but it will be a lot of amps without a relay. A simple temp probe or harness might be better/easier in the long run.
Use a big wrench and a hammer to get the clutch fan off. A pipe wrench or adjustable works. I ended up using a 18inch cheapie adjustable one from harbor freight and a fist maul.
Use the search function on the forum. I'm sure there's a few write-ups with pictures just in the gm engine/exhaust section.
thanks for the answer.
kalikid06
20
Oct 13, 2015 07:37 AM
Justin87gn
Sep 10, 2015 12:06 PM
97gmc
22
Sep 8, 2015 10:56 PM
USMCvet0311
Sep 4, 2015 09:43 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
