Bad smell from trucks air.
Old Feb 27, 2008 | 12:46 PM
5.3LGMC's Avatar
Default Bad smell from trucks air.
Well.....when i turn my heat on i get a stale burning smell that just stinks and it seems to go away for the most part when i turn it off or on cold??? Do i need a new heater core?
Old Feb 27, 2008 | 12:50 PM
beastmode's Avatar
Import Moderator
my 01' Silvy used to do the same thing
Old Feb 27, 2008 | 03:02 PM
La Riddler's Avatar
Yea, that is probably it. Anti-freeze inside the cab stinks like pee.
Old Feb 27, 2008 | 03:37 PM
quicksilverado's Avatar
Replace the in cab air filters under the glove box and it will take care of the problem.
Old Feb 27, 2008 | 08:42 PM
chevyguy7802's Avatar
^^^^what he said,and when you do chang em' youll be amazed with all the crap thats inside the filter!
Old Feb 27, 2008 | 08:47 PM
fastgmc53's Avatar
14 Second Truck Club
Thats really what happens when the heater core goes bad. It gets a small hole and leaks.......your passenger side floorboard should be wet a little also. If the heater core is under the dash like most.
Old Feb 27, 2008 | 09:01 PM
99LoweredSierra's Avatar
99 don't have the filter do they??
Old Feb 27, 2008 | 09:32 PM
They should. I believe 99-02 uses the same filter.
Old Feb 27, 2008 | 10:54 PM
budhayes3's Avatar
PT's Slowest Truck
My 99 has a cabin air filter...2 of em side by side actually IIRC...
Old Feb 28, 2008 | 07:20 AM
yea two side by side, under/behind glove box, you can get to them fairly easy it's just a plastic plate the 1" wide or so you take out the fastener and they drop down and out.
