are bad intake manifold gaskets common?
I'm having some serious symptoms of an air leak at wot. Right when I got WOT the first frame or 2 reads an o2 reading of around .920mV then it just shoots down to .750mV or so.....thinking maybe my intake manifold gasket is leaking. It's got 150k on it, 9 years old and the manifold has been off and on 2 times. Thoughts?
IMO your tune is really lean, that is why you are getting KR @ WOT.... The spike you see when you first hit the gas is "Lean-throttle-tip-in" fairly common.... You should start by tuning your VE table (preferably with a wideband) then tune your MAF (preferably with a wideband)....
Maybe I should load up a stock silverado SS tune and do that?
Problem is none of them had cable TBs
Could you modify the tune for me to make the necessary changes using stock parameters from an SS?
I attached a stock SS tune
