are bad intake manifold gaskets common?
Old May 19, 2009 | 06:52 PM
BlackGMC's Avatar
Resident Retard
is your truck stock? What all mods have you done to it?
Old May 19, 2009 | 06:53 PM
GMCtrk's Avatar
everything's all stock cept for the heads and 10.5-6:1 compression.
Old May 19, 2009 | 06:54 PM
blackbeast ss's Avatar
dont really think you can have a worn manifold gasket since it has zero movement... so i doubt your seal is the issue
Old May 19, 2009 | 06:58 PM
BlackGMC's Avatar
Resident Retard
I don't think you need a the SS tune copied over, you just need to tune the truck... Like i mentioned eariler.. Do a search on tuning with Long term fuel trims if you don't have a wideband.
Old May 19, 2009 | 07:00 PM
GMCtrk's Avatar
Justin suggested it was an air leak, that's why I focused on that.
Old May 19, 2009 | 07:07 PM
BlackGMC's Avatar
Resident Retard
Oh, in that case, go buy some intake gaskets, Justin knows his stuff... They are like $20...
Old May 19, 2009 | 07:29 PM
LowBlack99's Avatar
It's also a easy fix, should't take more than a hour or 2... I'm sure you have spent way more time with tuning. If it dosen't fix it then its kinda a no harm no foul repair, and you can eliminate that part and focus elsewhere.
Old May 19, 2009 | 07:59 PM
GMCtrk's Avatar
where for that price? gmpartsdirect is showing them for like $65?
Old May 19, 2009 | 08:04 PM
BlackGMC's Avatar
Resident Retard
wow i just checked oreilly autoparts and they are like 54, i could have swore i paid alot less that that....
Old May 19, 2009 | 10:20 PM
BigTex's Avatar
The older orange gaskets on 99-2003 trucks tended to leak. GM changed the design and materials some, now they are green.
