Attn: NewFrontMount Turbo requires a helmet!
Old Dec 17, 2006 | 05:47 AM
samdogmx's Avatar
8 Second Club
thats pretty impressive to me. I ran a 13.8 last year with 100 shot on stock tires.
this year I added a 2500 stall, shift kit, bigger cam, 33" tires on steel wheels & with the same 100 shot only ran 14.3
Old Dec 17, 2006 | 04:44 PM
02Reaper's Avatar
Originally Posted by CHEVY6000VHO
Do you understand the weight and size of tires this truck has? It's also just a 5.3L and the kit is only pushing 5psi.
What's not impressive about it?
What do you have that's "impressive"?
Jim
4440 lb 2002 5.3 silverado, bolt ons, cam, converter. 12.75 on motor, only weight reduction was the tailgate. Maybe I dont understand the weight and all the truck has. Let me go back and take another look.
Old Dec 17, 2006 | 04:49 PM
02Reaper's Avatar
Originally Posted by FarmTruc
To recap: '06 Sierra ext cab, 4x4, 33" tires, toolbox, full street trim, transgo shiftkit, 42lb injectors, upgraded fuel pump, Trick Performance front mount turbo 5psi, Nelson installed and tuned.
The truck ran a 13.77 @98.88 mph!!!!
60' was 2.08x
Nothing against anyone, I just dont get it I guess. Still not impressed for some reason. Sorry.
Old Dec 17, 2006 | 05:17 PM
kbracing96's Avatar
his truck will be in the neighborhood of 5500 w/driver. Go throw a 1000 lbs in your truck then put taller tires on it and you be singing a different song. I had to run 10 lbs on my 4.8 4x4 x cab to get to the mid 13's. Its a weight/ tire thing.
Old Dec 17, 2006 | 05:30 PM
02Reaper's Avatar
Really, How about weight to power. Ill bet he's got me by a bunch on the power. my truck only dynoed 320 hp and 315 tq. Also, I dont shed the 18*9.5's (285/50-18) at the track, they go also.
Old Dec 17, 2006 | 06:11 PM
thunder550's Avatar
High on diesel fumes
That's a 29" tire. Huge difference from a 33".
If you had 3.73's, he would have to run a 4.24 rear end to get the same effective gear ratio. Big difference.
So let's compare. You are 1000 pounds lighter, and if the general rule is 1/10th per 100 lbs, that's a 1 second difference. Then factor in the reduction in effective gear ratio, and let's give him another .3 seconds.
My guess is that this kit on a truck like yours would be good for mid to low 12's.
Old Dec 17, 2006 | 06:26 PM
nick993's Avatar
so is it for sale or is there a link im not seeing?
Old Dec 17, 2006 | 06:27 PM
thunder550's Avatar
http://www.nelsonperformance.com/ft_MountTurbo.htm
Doesn't look like it's officially for sale on the web site yet, but I bet you could call.
Old Dec 17, 2006 | 06:32 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
All the pissing and moaning about tire size will be over with next week when he puts normal size tires on it, I bet he drops 4/10ths with that. I did going from some 32.8" all terrain tires to 29.5 street tires.
Allen, what kind of flange does this thing have on the header? In a year or so I would like to get rid of the STS for a front mount setup but a much larger turbo for my 418.
Old Dec 17, 2006 | 07:42 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Tires make a huge difference, then add on the additional weight of most inexpensive aftermarket rims he has on it too...
Just to let you know, 35" tires took 100rwhp from a 5.3L, cammed, 10psi STS turbo.
I'm sure these 33's are taking at least half that!
Once we trade out the 33's with some stock ones, I bet it runs a 13.4.
Also, keep in mind this is a 4x4 ext cab as well. 1,000lbs more is on the light side, I bet it weighs about 1200lbs more.
We'll keep you updated,
allen
