Attention those with elec fans with Flex VSC and WIRING!!!
Old Jun 24, 2004 | 02:19 PM
  #31
therock's Avatar
Default Peel It
When I seen the melted holder I got a razor knife and carefully removed the outer soft rubber cover. This should help and I will peel my new one when it gets here. Don't try to cut it all the way to the wire. I (the rubber) will tear easy when you make a slit.
It shouldn't need it in the first place but what ever I can do I will. Mine is suspended where it can get air from the fans.
One more shot is all she gets before I send the VSC kit back for compensation. Then it will be a Delta.
Old Jun 24, 2004 | 02:30 PM
  #32
01Blackerado's Avatar
Well try the method i explained in the beginning you might be suprised...my fans run better now than they ever have. Just my 2 cents though
Old Jun 24, 2004 | 03:59 PM
  #33
Hit Man X's Avatar
I have ~1' wire between the VSC and the battery where the fuse is. My VSC is mounted to the side of the fuse box.
12awg wire can't hold the current of the LS1 fans, nor can that fuse holder.
Old Jun 24, 2004 | 04:53 PM
  #34
ThunderZ28's Avatar
12 Second Club
Holy cow!!!!! this morning the trans only got up to 125* and the motor from what the stock guage said only got up to about 180*
this was doing 25-70mph go down I-45 toward Galveston, Tx. from houston it's about a 40min trip
think it had to do with the fact that the truck was floating down the freeway
almost had to break out the oars
chvy=power
Oct 20, 2015 09:08 AM
kalikid06
20
Oct 13, 2015 07:37 AM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
