assembling short block today, need help
Banned
i'm putting the rods/pistons back in the block today and was wondering about ring GAP location. and is there a diferene in having one side or the other in or out on the pistons. is there any specific direction for the piston to face, i know there are only two options but which one is right? does that make sense to anyone? someone help me out here
the pistons should have a mark or dimple on em to mark the front if they are directional like the old small block pistons. as far as ring gaps go as long as they are staggered 180 degrees, they will be ok. try to offset the expander rings as well from each other.
Banned
which one is the expander ring??? i know i'm a retard, but the bottom is the oil ring i know...and the 6.0 pistons have 2 little dimples on them, one on either side.
Banned
fast, would you go ahead and send that please, the engine is a 6.0 but not the flat top piston varient of the 6.0 mine has the dished pistons with a dimple on either side. i'd really appreciate it man.
thanks
thanks
Banned
good deal...so i put both the oil rings the same way, and then the top ring gap 180 degrees in the other direction? thanks for sending the guide.
