ASP UD pulley questions!
Old Nov 1, 2013 | 06:51 PM
Slowest_1500's Avatar
Default ASP UD pulley questions!
I get paid next Friday, I've been eyeing this mod for a while over at TSP, which do I need? I'm lost with this stuff, and what belt? Noob questions, but I wanna know beforehand, thanks!
Old Nov 2, 2013 | 06:14 AM
Anyone?
Old Nov 2, 2013 | 08:30 AM
greasemykey's Avatar
89.5" belt for just the UD crank pulley and 90" if you run the ALT pulley as well
Old Nov 2, 2013 | 09:03 AM
zero2sixT's Avatar
Youre going to need a new bolt, a shorter accessory drive belt, and a shorter a/c belt.
This link should show you what you need, as far as belt size: http://www.aspracing.com/belt.htm#ctruckbelt
Don't look for any huge power gains, but every little bit helps imo.
you are also going to need to get the pulley install tool from Scoggin Dicky.
Old Nov 2, 2013 | 12:57 PM
craigsix's Avatar
i think slp is a better choice. on the fbody ls1 the asps were known to throw knock sensors.
Old Nov 2, 2013 | 01:26 PM
blnaway's Avatar
Registered User
This^^^ I did notice that the rpms pick up slightly faster when I first installed my asp pulley had on for yr and half haven't even had a check engine light
Old Nov 2, 2013 | 03:02 PM
Ferocity02's Avatar
Or you can make your own for relatively cheap, hardest part is finding the threaded rod.
Old Nov 2, 2013 | 03:23 PM
Thanks for all the info guys!
wrb002
Aug 25, 2015 03:56 PM
Bluchevypick
Aug 18, 2015 09:11 AM
chevysten
Aug 13, 2015 07:36 PM
USMCvet0311
Aug 1, 2015 07:45 AM
