asp pullies ordered!!!!!!
Old Sep 12, 2003 | 06:43 PM
one03sierra's Avatar
Formerly one92rs
Default asp pullies ordered!!!!!!
asp underdrive pulley and overdrive alternator pulley ordered.fast 4.8 do you have the number of the belt you used.or anyone using the same set up.
Old Sep 12, 2003 | 06:49 PM
NorCalLightning's Avatar
Default Re: asp pullies ordered!!!!!!
Are there any known problems with running these pullies (especially the alternator pulley)?
Old Sep 12, 2003 | 07:37 PM
Formerly one92rs
from what i hear no there isnt.
Old Sep 12, 2003 | 07:52 PM
FILE's Avatar
Nope... no problems here. You can get the belt #'s from here.
http://www.aspracing.com/frame.htm
Old Sep 12, 2003 | 08:04 PM
v8
17,16,15,14,13,12,11 Drvr
gates 60895 with crank only or 60900 with both pulleys but hte info will be in the box when you get them good luck and remember how i told you how to take the crank pulley off right
Old Sep 12, 2003 | 08:09 PM
Formerly one92rs
yay buddy if i need help i will get ahold of you to come help.
Old Sep 12, 2003 | 11:25 PM
ArticGMC's Avatar
O2denali I put a set on my 01 and the alt pulley squealed like a pig after and started eating some of the belt after about 100 miles. I had the belts that they were the right ones too. I sent it back to asp and the new one that they sent me did the same thing even with a gatorback belt that is not supposed to squeal. I've heard that getting a slightly smaller belt resolves the problem though.
Mine stopped squealing when I put the 130 amp alt on.
lar
wickedRCSB
Oct 30, 2015 09:45 PM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
