ASP or Powerbond
Old Sep 24, 2008 | 10:36 AM
lucky77's Avatar
Banned
Default ASP or Powerbond
What's the difference between the ASP / powerbond underdrive pulley, Besides the Price? which one do you all recommend ?
Old Sep 24, 2008 | 10:57 AM
BlackGMC's Avatar
Resident Retard
I have a powerbond pulley and it is ok I guess, never had an underdrive pulley before sooo, didn't really notice much with it, does look better thou... But I would definately order a long bolt when you go to install it... The factory bolt was tooo short to get it started... Oh and I had to order a ASP overdrive Alternator pulley, cause my volts were down at idle 13ish instead of 14ish....
Old Sep 24, 2008 | 11:23 AM
jakebdb56's Avatar
They both function the same, like BlackGMC said you would benefit from an alt. overdrive pulley. I have a crank pulley install tool that makes crank pulley installs a 2 minute job. If you're interested in one pm me.
Old Sep 24, 2008 | 01:42 PM
ZR1 DREAMING's Avatar
I've had them both. Actually, I have one of each LOL. Think of it like MSD vs Taylor wires... both serve their purpose, some like one some like the other. IMO, pick up the cheapest and put the savings toward something that'll help you out more.
Old Sep 24, 2008 | 06:03 PM
andrew383's Avatar
traveling mod
i have both... go with the powerbond. looks better to
Old Sep 24, 2008 | 06:20 PM
TouchOfEvil04's Avatar
Powerbond is heavier than the asp. Heavier than the stock one even.
Buddy had a powerbond for a couple days and got rid of it.
Ethier way your gonna want the alt overdrive like said above.
Old Sep 24, 2008 | 06:22 PM
I have the asp but it doesnt matter just go with the cheaper one. I didnt need a longer bolt while installing the asp. With the overdrive alt pulley my volts were lower so I put the stock one back on.
Old Sep 24, 2008 | 08:37 PM
andrew383's Avatar
traveling mod
what you guys with 04 and older trucks dont know is the 05 newer trucks have a power mangement system,it basicly tells the alternator what voltage to put out.there's a amp meter like clamp that goes around the neg battery cable to monitor the load.so unless you got a MASSIVE system in your truck you dont really need the alt pulley.
Old Sep 24, 2008 | 08:46 PM
phasemaster1's Avatar
Just removed my ASP underdrive off my truck. Had to remove it Installed procharger needed to install stock balancer back in. Also have alt over drive pulley. If interested pm.
Old Sep 24, 2008 | 08:48 PM
Originally Posted by andrew383
what you guys with 05 and older trucks dont know is the 06 newer trucks have a power mangement system,it basicly tells the alternator what voltage to put out.there's a amp meter like clamp that goes around the neg battery cable to monitor the load.so unless you got a MASSIVE system in your truck you dont really need the alt pulley.
I have an 05 and have this also, when you put underdrive pullies I have heard you need to have the idle turned up a bit.
