ASAP tap question
Old Jun 27, 2006 | 02:48 PM
LesPaul's Avatar
Default ASAP tap question
i gots a 5.3, what size tap do i need for the 11mm bolt holes on my head
Old Jun 27, 2006 | 03:07 PM
SS_bnoon_SS's Avatar
Number 1: Use a thread chaser, NOT a tap! It's not the same thing, and the threads can be damaged using a tap...
Number 2: Sorry, I don't know the size needed...
Old Jun 27, 2006 | 03:12 PM
LesPaul's Avatar
thanks for correcting me... yes i am needing a chaser not the tap
Old Jun 27, 2006 | 03:23 PM
moes04silverado's Avatar
what did you do break off a bolt in there??? use lefty drill bits....
i busted one off in the passenger side/last spring closes to the firewall....had to pull the head and used those lefty drill bits and got it out...
Old Jun 28, 2006 | 04:52 PM
No no no, you use a thread chaser to clean any dirt/etc from the already drilled/tapped bolt holes when rebuilding an engine to ensure that you get an accurate torque reading when putting in new bolts/studs.
Old Jun 28, 2006 | 07:49 PM
5.3 racer's Avatar
don't know what size either but i bought a set from ARP, pretty sure they are listed on their website....
Old Jun 30, 2006 | 07:23 AM
ah got ya!!!
Old Jun 30, 2006 | 08:32 AM
Colby 04's Avatar
How did you break a bolt off?
Old Jun 30, 2006 | 09:35 AM
Nobody broke a bolt...
Old Jun 30, 2006 | 10:10 AM
kerryt1's Avatar
You need an 11mm tap. For the record, I have never seen an 11mm thread, so double check. If you want to be really certain of the threads, go to Lowe's or Home Depot and use their thread gages to check it.
I don't know about this "thread chaser." There are different types of taps (tapered, bottoming, etc), sure. Anyway, you should be fine using a tap, just try and thread it in with your hand. If you have to use a tap handle, use as little force as possible. You'll be able to tell when it's cutting. Make sure and lubricate it to. You can use something like Tap Magic, but for thread chasing, WD-40 or motor oil would work. Just make sure you blow the hole out with compressed air before you install the bolt.
lxcoupe
13
Nov 20, 2015 08:43 PM
bisqikss
Sep 8, 2015 03:35 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
Hpinnovate
Sep 4, 2015 02:28 AM
