ASAP 2004 Short Head Bolt 5.3 TQ Specs
Old Jul 29, 2008 | 05:04 PM
Formulized94's Avatar
Default ASAP 2004 Short Head Bolt 5.3 TQ Specs
Can anyone tell me the tq specs on the 04 short head bolts for a 5.3?
i think it is 90* then 50* any help is appreciated.
-Ryan
Old Jul 29, 2008 | 05:25 PM
Truckshop's Avatar
1st design
Cylinder Head Bolts - First Design - First Pass all M11 Bolts in Sequence 30 Nm (22 ft. lbs.)
Cylinder Head Bolts - First Design - Second Pass all M11 Bolts in Sequence 90 degrees
Cylinder Head Bolts - First Design - Final Pass all M11 Bolts in Sequence - Excluding the Medium Length Bolts at the Front and Rear of each Cylinder Head 90 degrees
Cylinder Head Bolts - First Design - Final Pass M11 Medium Length Bolts at the Front and Rear of each Cylinder Head
2nd design
Cylinder Head Bolts - Second Design - First Pass all M11 Bolts in Sequence 30 Nm (22 ft. lbs.)
Cylinder Head Bolts - Second Design - Second Pass all M11 Bolts in Sequence 90 degrees
Cylinder Head Bolts - Second Design - Final Pass all M11 Bolts in Sequence 70 degrees
Cylinder Head Bolts - M8 Inner Bolts in Sequence 30 Nm (22 ft. lbs.)
Old Jul 29, 2008 | 06:48 PM
Thank you Sir.
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
steves86ta
Jul 28, 2015 10:21 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
NuckenFuts
Jul 9, 2015 08:45 AM
