ASAP 2004 Short Head Bolt 5.3 TQ Specs
1st design
Cylinder Head Bolts - First Design - First Pass all M11 Bolts in Sequence 30 Nm (22 ft. lbs.)
Cylinder Head Bolts - First Design - Second Pass all M11 Bolts in Sequence 90 degrees
Cylinder Head Bolts - First Design - Final Pass all M11 Bolts in Sequence - Excluding the Medium Length Bolts at the Front and Rear of each Cylinder Head 90 degrees
Cylinder Head Bolts - First Design - Final Pass M11 Medium Length Bolts at the Front and Rear of each Cylinder Head
2nd design
Cylinder Head Bolts - Second Design - First Pass all M11 Bolts in Sequence 30 Nm (22 ft. lbs.)
Cylinder Head Bolts - Second Design - Second Pass all M11 Bolts in Sequence 90 degrees
Cylinder Head Bolts - Second Design - Final Pass all M11 Bolts in Sequence 70 degrees
Cylinder Head Bolts - M8 Inner Bolts in Sequence 30 Nm (22 ft. lbs.)
2nd design
FlowmasterMufflers
Jul 17, 2015 03:26 PM
