ARP Rod Bolts
Old Feb 13, 2007 | 12:23 PM
LMK2005's Avatar
Default ARP Rod Bolts
Allright fellas. I'm working on gettin my 6.0L all ready to go. I was wondering how hard it is to change out the Rod Bolts. Or if someone knows of a thread with a How To. I'd like to do it all while i have the motor out. So if anyone can help me out that would be great. I have a Comp 224/224 .581/.581 112lsa cam. and the heads are going to be milled 30-40 thousandts. Give me some input.
Old Feb 13, 2007 | 04:23 PM
Tootall's Avatar
doing rod bolts while the engine is out, that's easy. There's a torque sequence, and that's about it.
Old Feb 13, 2007 | 05:19 PM
Be sure to pull out all of the little ferrules in the rods,it will throw off your torque if you dont remove them.When you loosen the bolt out of the rod use channel locks to pull out the ferrule and bolt as one. You will see what I mean when you do this.
Old Feb 14, 2007 | 06:38 PM
LMK2005's Avatar
so the bolts are not pressed in or anything? They just unscrew pretty much and you screw the new ones in?
Old Feb 14, 2007 | 09:00 PM
Tootall's Avatar
yeah, they're just bolts. They're bolted threw the rod caps, then threw to the rod itself
Old Feb 14, 2007 | 09:25 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Do 1 rod at a time. They are cut and mated. Unscrew old bolt, tap out the ferrel, screw in ARP bolt. TQ to specs. Should take about 20 minutes on an engine stand.
Old Feb 15, 2007 | 08:28 PM
LMK2005's Avatar
Allright, Thanks guys
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
Yohns Kustom Fab
Aug 25, 2015 06:53 AM
Jake75
Aug 5, 2015 01:26 PM
Ammadien
Jul 22, 2015 08:50 PM
