anyone use type-f transmission fluid?
i have heard that you can used type-f transmission fluid, in place of dextron-3 fluid. the reasoning for this is that type-f is better for firm shifts. it doesnt allow the clutches to slip as much as dextron-3. it has been called "a shift kit in a bottle". i was wondering if anybody has heard this too? is it something that should or shouldnt be done? are there any adverse effect on the transmission life?
Cuz I AM a BADMOFO
Here is the link to the discussion that was in the transmission forum:
https://ls1tech.com/forums/showthrea...fluid+type+atf
After reading this, I am undecided, but I will probrobally leave it alone.
Type-F is powersteering fluid too...
Why is the reason behind using a non recommeneded fluid? B/c it's slightly thicker? DexIII/Mercon is so cheap just change it often and be done with it. I just do a fluid swap every 10K mi.
