Anyone tow a lot with electric fans?
#31
ih ya, i have pulled the grade many times, i usually don't slow to les thatn 45 mph. i was thinking that the added hp to the tires would help lay off the throtle some too helping to keep the engine temps down...
in another note, flex a lite even makes an electric fan kit for diesel trucks so i assume they could keep a gas motor cool...
Anyone know what cfm a clutch fan pulls?
i say get the 05+ efans.
I recently pulled my jeep down to TN and goin up the mountian had to geter down in 2nd doin about 55mph for 2-3 miles and the temp never got off 190 (via aeroforce) but the trans temp...thats a different story lol
#32
I would get a big trans cooler for considering the towing.
there was a time i drove to salt lake city in dec, 12* - 20* out, at hwy speeds the trans temp was at the bottom of the gauge
ok so where do i go about getting the 05 + fans from???
WHat all am i looking to get to make it work?
#33
The 05 efans require a 34" radiator which you should already have since you have a 6.0 HD.
#34
first, i want to ask about your tranny temp, how high does it get while pulling up that grade?
and on the questions around here, i was one that used to have issues with my efans while sitting in traffice with the a/c, my temps woul climb up to 220 pretty quick and i always had to turn off the a/c until i would get back up and rolling, then once i put the clutch fan back on everything would be ok? both were with a 160 thermostat.... then i found my problem.... i had an AIR POCKET in my coolant system! yup, that will give people hell if its not done properly..... now i still have the clutch fan and can sit in traffic with the a/c and it will run around 200-203...
something for yall to think about, make sure your coolant system is bled right...
also, i dont think its worth the swap for the little horsepower you get out of it...
im thinking about doing a baby cam swap on my 2500HD, something to gain 20-30rwhp on the low end 2000-3500rpm...
#35
#38
How many of you with overheating problems have a low temp thermostat? I had all kinds of overheating problems with both a 160 and 180 t-stat, both with a clutch fan and e-fans. As soon as I put a stock one back in there all the problems are gone.
To the OP - I have towed 6000 lbs up a good grade for 2 miles at 5 psi boost on my 408 with the e-fans running on high and a/c blasting, 100* outside and never got over 214.
I say just upgrade to the 05+ radiator/e-fans... its what im saving up for so I (hopefully) wont have these problems ever again.
