anyone with swapped 6.0 in here
Old Jan 2, 2008 | 10:42 PM
CHEVRACER83's Avatar
Default anyone with swapped 6.0 in here
who here has swapped to a 6.0... if you came in hopefully you...
i have a friend swapping his 2001 4.8 out to put in a 6.o... he will be using his built 60e, and 2800 stall to back the 6.0
i know most stuff will bolt right up... but what wont?? i know the 6.0 uses a spacer on the flexplate... you dont need it on teh 60e right?
also can the stock flexplate be bolted to the 6.0?? all he has bought is the motor... what else will he need?
Old Jan 2, 2008 | 10:52 PM
bigbadwolf54's Avatar
13 Second Truck Club
I used everything from the 5.3 when I swapped, didnt have to use a spacer at the flexplate. I think the early 6.0's had diff length crankshafts though..the ones with iron heads, so that would throw you off but other than that everything swapped over for me.
Old Jan 2, 2008 | 11:03 PM
silveradol33's Avatar
Yea, all my stuff swapped over from the 5.3 on my last truck. It worked perfect on the 6.0.
Old Jan 2, 2008 | 11:04 PM
thank you adam... much help
Old Jan 2, 2008 | 11:06 PM
thunder550's Avatar
High on diesel fumes
As stated above, a 6.0 swap is as simple as pulling one out, swapping the flexplate from the old one to the new one, dropping the new one in, and re-installing all of your accessories.
Old Jan 2, 2008 | 11:08 PM
thanks chris... this is getting better and better... now if one of you wants to give me a ride to kansas i can help him swap it
Old Jan 2, 2008 | 11:20 PM
haha well I'm in Oklahoma...thats close to kansas
Old Jan 2, 2008 | 11:24 PM
haha... closer than me
Old Jan 3, 2008 | 12:44 PM
SRT10KLLR's Avatar
Former Vendor
I just did that and everything just swapped over from the 5.3 to the 6.0. Now if I could get oil pressure I would be fine.
Old Jan 3, 2008 | 01:37 PM
Tootall's Avatar
I've done 3 now !
as long as it's a regular length crank, EVERYTHING swaps over . . . . remember, all he needs to swap is the long blocks, and nothing else.
