Anyone install the Meziere pump on a truck
Old Nov 19, 2003 | 02:02 PM
eallanboggs's Avatar
Default Anyone install the Meziere pump on a truck
I know the Meziere was designed for the F-bodies, but has anyone had sucess installing it on the truck LS1? Meziere told me they sell a shorter hose fitting for the top radiator hose. It's a threaded screw in fitting that might help reduce the tendancy of the hose to kink. I'm wondering if the top radiator hose will kink if it is forced on staight fitting since the truck fitting is angled upward at 45 degrees. I also read that you need to use the F-body serpentine idler pulley. Is this because the truck pulley rubs the Meziere pump body? This mod would give a decent gain when combined with swapping the flex fan for electric fans.
Old Nov 19, 2003 | 03:02 PM
Hit Man X's Avatar
Do a search in this forum a few months back. Someone installed it, documented it with pics, and all. Nice writeup.
It'd be even better with an ASP pulley set, e-fans, and e-waterpump.
The_W
Oct 28, 2015 09:00 PM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
MileHighSierra
Jul 12, 2015 12:23 AM
