Anyone in here running a TR230?
Old Mar 10, 2008 | 10:41 AM
2002C5COUPE's Avatar
Default Anyone in here running a TR230?
Just wondering if anyone has a TR230 (reverse split) cam, and how they like it.
I'm considering a cam swap while my engine is tore apart
Old Mar 10, 2008 | 12:17 PM
Zick's Avatar
I ran that cam in my old 03' (see sig).
I ran great but I didn't get the full potential out of it due to not having any LTs. It definitely needs to breathe. Oh and bigger stall I'm sure would have help but as a daily driver it was fine.
Edit: I just saw your setup which looks like you will be setup great for it. Only other thing I had different was the 243 heads which bumped up my compression.
Old Mar 10, 2008 | 01:27 PM
ZZebes's Avatar
Sounds like the MTI X1 i ran, great cam for all around use
Old Mar 10, 2008 | 01:31 PM
I'm looking at the X1 cam and the TR230. They're so similar i probably wouldn't be able to tell the difference.
Hopefully i will pick up some hp with one of those cams and an LS6 intake when i get it back together
Old Mar 10, 2008 | 05:33 PM
MGMC's Avatar
12 Second Club
i was debating between the two also, then i found a deal on a x1 and decided on it. ill have the in this weekend hopefully. my set up will be a bolt-on(except udp) LQ4 with mid-legnths
stealthperf
34
Feb 14, 2016 11:35 AM
The_W
Aug 15, 2015 08:07 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
Mzay
Jul 6, 2015 11:03 PM
