Anyone have the 216/220 cam? Does it lope in a 4.8?
Old 10-16-2013, 11:08 PM
Fast86z's Avatar
Default Anyone have the 216/220 cam? Does it lope in a 4.8?
Looking for a cam for my turbo 4.8 and want a little bit of chop. This is an open downpipe off the turbo. Does this cam have a noticable lope at idle? Is this cam a good choice over the stock cam? Thanks.
Specs are 216/220 114 LSA,
Old 10-17-2013, 12:27 AM
Mod with training wheels
smokeshow's Avatar
That'll have a little bit of chop. Not much, but definitely noticeable.
Old 10-17-2013, 10:26 AM
11 Second Club
batboy's Avatar
Originally Posted by Fast86z
Specs are 220/224 114 LSA
The title says: Anyone have the 216/220 cam? Does it lope in a 4.8?
Which cam are you talking about? Get a cam with a lower LSA if you want a lumpy idle, like 111 or 112. The Texas Speed cams usually have a choice of LSA. Longer duration cams will also have a rougher idle due to more overlap.
Old 10-17-2013, 01:45 PM
Fast86z's Avatar
Thanks! The post says 114 lsa. This is an off the shelf cam.
Old 10-17-2013, 02:27 PM
Ferocity02's Avatar
My 212/212 114 has a good amount of lope at 700RPM on my 5.3L. I have a cutout at the end of the downpipe and anyone would notice the lope with it open. Less noticeable when the cutout is closed and its running through the big Magnaflow muffler. No vids unfortunately.
I guess it depends on how much lope you want.
Old 10-17-2013, 09:17 PM
Steve-O-08's Avatar
Fast86z,
Batboy was pointing out that the cam specs in the title were 216/220 and the specs in the post were 220/224
Every setup is different. Exhaust, Tune, etc. Should lope a little. not anything like a 110-112 lsa cam.
Old 10-17-2013, 09:20 PM
03sierraslt's Avatar
In a 4.8 both the cam in the thread title and the cam in the actual thread will have some lope.
Old 10-17-2013, 10:48 PM
Fast86z's Avatar
OOPS! LOL!! Ok I just corrected it, cam in question is in fact the 216/220 114 cam. Thanks!
Old 10-18-2013, 11:33 AM
BLACKND's Avatar
It should have some lope to it. I ran that cam in my 04 5.3, thru the exhaust it wasn't TOO noticable, with the cutouts open, you could definitely here a mild chop.
Old 10-18-2013, 12:15 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
My 216/224 115 has a lope in my 5.3, so I'd say a 216/220 114 should have a decent lope/chop in a 4.8.
Quick Reply: Anyone have the 216/220 cam? Does it lope in a 4.8?
