anyone has issues with LS1 fans?
Old May 11, 2010 | 07:44 PM
ap2002's Avatar
Default anyone has issues with LS1 fans?
i started daily driven my truck and it seems that the trucks heats up pretty quick in stop and go traffic, temp will climb up pretty quick to 220-230.... i thought i had an air pocket so i did my best to get rid of it and i also bought a new radiator cap just for the hell of it, well that did nothing, today i was pissed off at the **** and i swapped the stock clutch fan in and what do you know temp never goes over 195F?? WTF??? do yall think the LS1 fans dont push enough air compared to the stock fan? i know plenty of people running them with no issues but im just wondering why in the hell im having trouble with it....
Old May 11, 2010 | 08:02 PM
budhayes3's Avatar
PT's Slowest Truck
What temp do you have them set to come on at? Maybe that's the problem...or they may not be turning fast enough for some reason...
Old May 11, 2010 | 08:14 PM
Atomic's Avatar
I have a gauge for that
...are they coming on?
Old May 11, 2010 | 08:17 PM
dlt76028's Avatar
like said above, are they coming on? and what temp?
Old May 11, 2010 | 08:34 PM
Wheatley's Avatar
Truck Sponsor
Same fans as you have always run AP?
I ask because it has never had problems before
Old May 11, 2010 | 08:44 PM
ap2002's Avatar
I have a 160 thermostat, and my efan harness is not temp control, its just a switch for hi or low speed, i always have them on hi unless im on the highway, and yes both fans were on and on hi speed everytime i checked them, i would just stop and open the hood with the truck running and temp would start dropping fairly quick,? im confused?
Old May 12, 2010 | 12:44 AM
SilverDog's Avatar
I would make sure the fans are pressed against the core fully. I assume you check to see if they're pulling not pushing.
Old May 12, 2010 | 12:46 AM
00ChevyScott's Avatar
Wearin' da big hat
Might need to take the hose and spray it through your radiator to clean out all the dirt and bugs lodged in it, and make sure your fans are pressed up against the radiator fully.
Old May 12, 2010 | 11:32 AM
budhayes3's Avatar
PT's Slowest Truck
Good call...you could always unbolt the radiator at the top and tilt it towards the engine to look and see if there is excessive leaves/bugs/debris between the radiator and condensor...
Old May 12, 2010 | 11:51 AM
dlt76028's Avatar
the radiator wouldn't explain why it ran cool with the clutch fan.
