Anyone with an 02 v8 truck
Old Jan 15, 2009 | 11:28 AM
retsell's Avatar
Default Anyone with an 02 v8 truck
I need a favor. I have a broken ground wire on my truck, and I can't find where it went to. If you open your hood and look down between the front of the engine and the shroud you should see a ground wire bolted to the center of the frame crossmember. Mine has broken off on the other end and is just dangling from the frame. I need to know where it goes. I looked at a 99 and it doesn't even have the wire bolted to the frame, so I need someone with an 02 (dunno if other years have it) to look and see where it goes.
Old Jan 15, 2009 | 11:49 AM
Mangled03gmc's Avatar
Baltimore Whore
If I remember correctly it connects to the front driver side of the oil pan, or some where in that area... Worst case is leave it off, there are more then enough grounds on your engine
Old Jan 15, 2009 | 11:53 AM
retsell's Avatar
I was thinking that was probably where it went, but I didn't know. I wouldn't worry about it, but i'm chasing down an idle surge problem and I want to eliminate any possible problems. I'm pretty sure it's an intake leak...
Old Jan 15, 2009 | 11:56 AM
Baltimore Whore
Yes pos or something in the vacuum system..
Old Jan 15, 2009 | 03:56 PM
2 tone 02's Avatar
I know the wire you are talking about, but I forget where it goes. Somewhere on the lower block or oil pan.
Old Jan 15, 2009 | 03:59 PM
banker099's Avatar
the ground wire that is on the front center of the crossmember goes on the rack and pinion...or thats where mine goes(i have no idea why, so dont ask )...mines an 02
after going back and reading the first post...mine is more like a small ground strap...not a wire...prob still the same
Old Jan 15, 2009 | 04:35 PM
aksz71's Avatar
mine is an 02 and it dont have one..
Old Jan 15, 2009 | 10:11 PM
SnakeOiler's Avatar
Ditto.
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
