anybody just move a conventional old style pvc to the valley cover
Old Sep 15, 2017 | 04:19 PM
Truckeez's Avatar
Default anybody just move a conventional old style pvc to the valley cover
... with a regular old SBC valve cover grommet?
I don't see why it wont work fine.
Old Sep 15, 2017 | 06:01 PM
Atomic's Avatar
I have a gauge for that
For the turbo builds I do I usually drill and tap the valley cover for a half inch npt fitting and run it to a breather can.
Old Sep 16, 2017 | 03:56 PM
Truckeez's Avatar
And you cap off the throttle body fitting wit a black rubber ?
Old Sep 16, 2017 | 05:10 PM
Atomic's Avatar
Yea, or remove it and drill and tap for an NPT plug.
Old Sep 17, 2017 | 02:59 PM
madmann26's Avatar
The ls6 valley plate has it built in and is a nice design.
You may have to notch the block to get it in however.
Old Feb 12, 2018 | 05:36 PM
Burnett03's Avatar
What do you do with the rest of the system? Do you run just the valley plate fitting to a catch can?
Old Feb 12, 2018 | 09:37 PM
Atomic's Avatar
Whatever you want to. I usually pull off one or both covers as well. The air needs somewhere to go, oblige it however you see fit.
Old Feb 12, 2018 | 10:42 PM
Sevex's Avatar
Snail Fab
I do the same as Atomic, I run a -10 off both valve covers and a -10 off the valley cover to my catch can my intake gives me alot of room though.
Old Feb 12, 2018 | 10:56 PM
Atomic's Avatar
Very nice! Your aluminum welding is definitely better than mine.
Here is my combo tank I have made a few of, basically same thing, coolant tank catch/breath can combo. You cant see it, but there are tubes and a plate with a bunch of small holes to act as a baffle inside the breather can.
Attached Thumbnails anybody just move a conventional old style pvc to the valley cover-24313071_2000647163515750_2211440301256901409_o.jpg   anybody just move a conventional old style pvc to the valley cover-24302411_2000647130182420_1110412157642862415_o.jpg
Old Feb 13, 2018 | 10:06 AM
Burnett03's Avatar
I like your breather/overflow setup atomic. PM me a price please.
