Anybody ever had a wideband sensor fail?
Old Nov 3, 2004 | 01:40 PM
BlownAlaskan's Avatar
Default Anybody ever had a wideband sensor fail?
Last night, I flipped my FJO wideband on and it was pegged on 20:1. This was at idle and I am pretty sure it was a bad reading. Think the sensor is bad??
Old Nov 3, 2004 | 02:16 PM
hellbents10's Avatar
LS1Tech Sponsor
Do you have a exuast leak. I have had a few die on me. It could just be seeing the extra air from the exuast leak.
Old Nov 3, 2004 | 03:08 PM
No exhaust leak... sealed tight.
Old Nov 3, 2004 | 03:19 PM
Widebands do not cater too well to being left in exhaust pipes while not being used (heated)
The reason it's a 5 wire sensor is that a couple of the wires are for a heating element. Not heated, the sensor will clog up and fail.
Well that would be my general diagnosis.
Old Nov 3, 2004 | 03:27 PM
It just sucks how expensive they are!!!
Old Nov 3, 2004 | 03:41 PM
Black Blown 02's Avatar
I wonder if you burned it up with that exhaust leak you had a while back?
Old Nov 3, 2004 | 07:50 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Leaded fuel ie. race gas is also hard on the sensors. Don't know if you run any, but high octane race fuel will also burn up the sensors.
Old Nov 3, 2004 | 08:23 PM
parish8's Avatar
single digit dreamer
i think the lead can plug the sensor, not burn it up. i know leaded fuel is not good for them but i probably have 300+ gallons of 118 on my original sensor.
definately not suppose to leave the sensor in if the controler isn't hooked up and running
Old Nov 3, 2004 | 11:31 PM
So... Is using the optional guage the only way to keep it running all of the time? Or, does the sensor being hooked up to the control box keep it warm all of the time?
Old Nov 4, 2004 | 06:39 AM
parish8's Avatar
you can leave the control box hooked up and it will be running all of the time, you just wont be monitoring it. the other option is to pull the sensor out when you are not using it.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
