Anybody eating coolant on their 6.0's?
Old Mar 23, 2005 | 07:04 AM
beertestr's Avatar
Default Anybody eating coolant on their 6.0's?
I had a guy come by today asking about Gen-III motors eating coolant. He has a friend with a 6.0L LQ4 truck. He only drives it a little each week, to and from the store mostly. However, he also hauls his antique tractors with it. He has noticed that his motor is eating a little coolant, maybe a pint-quart a week. No puddles.
Is anybody else's motors eating coolant. I have beaten the p!ss out of many 5.3L Iron and Aluminum motors, Iron and aluminum 6.0's and have not had this problem before. Just curios to see what others have experienced.
THNX
Old Mar 23, 2005 | 07:09 AM
Deckhand's Avatar
weird... coolant leaving without puddles is a symptom of a leaking headgasket
Old Mar 23, 2005 | 07:49 AM
marc_w's Avatar
Mine has gone down about an inch or so since I filled it during my last cam-swap this past August...
That raised a flag with me, but I'm not too concerned right now.
Old Mar 23, 2005 | 09:09 AM
beertestr's Avatar
That's whay I thought, but he's not losing as much coolant as you would think if the head gasket is the problem, and he has not abnormal cooing system pressure issues, another good sign of HG problems. I wonder if his water pump is going. I had one going on my LT1 once, and it never left a puddle, but I sometimes smelled coolant. It was weeping out the weep hole at the bottom of the casting, and not enough to puddle, it seems it would evaporate pretty quickly..
Old Mar 23, 2005 | 09:24 AM
JERRY2500's Avatar
14 Second Truck Club
Mine did it for about a month, then it quit and had no signs of leaking.
Old Mar 23, 2005 | 10:51 AM
jlwz71's Avatar
There is a TSB out on the coolant cap not sealing. Mine did the same thing until I replaced the cap with a Stant one.
Old Mar 24, 2005 | 10:26 PM
Black04HD's Avatar
Tsb??
Old Mar 24, 2005 | 10:28 PM
99Silver6.0's Avatar
Originally Posted by Black04HD
Tsb??
Technical Service BUlletin.
Old Mar 25, 2005 | 01:44 AM
Green Thunder's Avatar
TSB
Engine Runs Hot, Overheats, Loss of Coolant (Polish Filler Neck/Replace Radiator Cap) #00-06-02-001 - (Jan 5, 2000)
Engine Running Hot, Overheating and/or Loss of Coolant (Polish Radiator Filler Neck and Replace Radiator Cap)
1999-2000 Passenger Cars and Trucks
with Composite Radiator End Tank
Condition
Some customers may comment on one or more of the following conditions:
Engine running hot
Engine overheating, and/or
Loss of coolant/low coolant message
Cause
The radiator filler neck may have an imperfection in the sealing surface.
Correction
Important
DO NOT REPLACE THE RADIATOR.
Using a piece of 400 grit wet/dry sandpaper backed with a flat piece of wood, polish the filler neck sealing surface using a circular motion.
Replace the radiator pressure cap with a cap of the same part number as shown in the GM Service Parts Catalog.
Old Mar 26, 2005 | 02:16 PM
busta9876's Avatar
if you still suspect head gaskets, there are a few simple things you can do.
hook up a scantool and watch misfire counts at cold startup. sometimes the coolant in a cylinder will be enough to cause misfire at startup, but not enough to set the DTC P0300 (misfire detected)
another thing. most auto parts has a kit to test the engine coolant for traces of combustion gasses in the coolant system.
bearden86
26
Nov 15, 2015 03:58 PM
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
