any swaps i can do?
Old Nov 7, 2009 | 05:04 PM
Brandon511's Avatar
Default any swaps i can do?
I have a 1998 GMC sierra Z71 and it came with the 5.0L and i was wondering what swaps can i do,or what is the best performance upgrades for this motor,it already has intake and tbs.
Old Nov 7, 2009 | 05:11 PM
budhayes3's Avatar
PT's Slowest Truck
For a fairly direct swap, I'd check out GM's crate 383 If you wanted to get more involved, you could swap in a GENIII mill, such as a 6.0 or 408 stroker
Old Nov 7, 2009 | 05:22 PM
Brandon511's Avatar
come on fill me in what all do i need for the 6.0l and how do i make a 408 stroker?
Old Nov 7, 2009 | 05:41 PM
SweetS10V8's Avatar
A lot of research....
Old Nov 7, 2009 | 07:43 PM
budhayes3's Avatar
PT's Slowest Truck
Check the internal section here for what's needed to build the stroker, tons of info, just have to use the search and go to town
I'm guessing that the 6.0 swap would require the engine with accessories, harness, PCM, motor mounts, trans crossmember modification, driveshaft modification...the list goes on. I know that it's been done, and it sounds worse than it actually is, but in the end it's a nice swap
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
superchomper2003
Aug 26, 2015 09:39 AM
iregret
Jul 27, 2015 10:32 PM
