Any engine builders in here need opinions
Old Jan 18, 2013 | 03:20 AM
Suburbazine's Avatar
Originally Posted by javier4.8
Now where can I find some bolts for the bottom main. Does arp make them.
Put a camera on a tripod for the first time you start it. That way the whole world can know if you succeed or fail.
Hell, I'd say I'm a halfway decent mechanic and I still wouldn't attempt a 408 build myself (Namely, because I'd put a new engine in a car before I did a bottom end). I'd let a machine shop do it, preferably one that has years of experience in custom work.
Old Jan 19, 2013 | 09:19 AM
RezinTexas's Avatar
the critical steps are:
1. measuring main, rod, and cam bearing clearances with dial bore gauge and micrometer - $$$ tools
2. file fitting piston rings
3. torquing rod bolts and verifying bolt stretch
4. measuring installed piston deck height
5. spacing/clearancing windage tray for stroker crank
anyone can do it, but it requires some new tools, lots of patience, and a clean workspace.
i suggest buying Joseph Potak's book, that is a great place to start
Old Jan 19, 2013 | 09:30 AM
TXSZ66AVLANCHE's Avatar
Cleanliness is probably the most important thing after measuring for proper clearance. I still think u should have the machine shop assemble the short block, this ain't no stock 5.3 rebuild.
Old Jan 19, 2013 | 09:52 AM
RezinTexas's Avatar
FYI, this was my first build and the cost of special tooling FAR outweighed the cost for a shop to put it together. only do it if you really want to, don't look to do it as a way to save money or time.
2500ZL1
Jan 25, 2016 06:30 AM
urdone
Aug 18, 2015 12:17 PM
lawhitediamante
Aug 12, 2015 12:14 PM
DrX
Aug 11, 2015 07:25 AM
therock
Jul 25, 2015 09:23 AM
