Any Diablosport Users here?
Old Feb 17, 2005 | 06:48 PM
Default Any Diablosport Users here?
My free tuner will be here tomorrow and I had a question on the tq management.
Has anyone turned this off? How does the transmission feel afterwards? I see on the diablo site that they do not recommend it.
I Do not mind a good hard shift but if it is going to make it sloppy of what not I do not want to do it then.
I know I should do the nelson tune but money is tight and this is free...
Any help would be greatly appreciated.
Old Feb 17, 2005 | 07:39 PM
goshawk23's Avatar
Truck addict
i use it and you have to have a custom tune in order to delete any tq management. i had mine autotapped and on the 2-3 shift there was only a small percentage removed. predator changes different tables than edit. or i'll say not all the same tables. if you don't go crazy on the line pressure and speed adjustment for shifting it will feel nice and crisp. but go overboard and you'll feel your dash shake everytime you shift. it is a good handheld. i rate it above all other handhelds. but as far as tunes go, you are leaving hp on the table. but yours is free, hard to argue with that price.
Old Feb 18, 2005 | 08:44 AM
slowec's Avatar
Default Telll us more
Any guys that have predator knowledge , would you please share.What works when setting up the tune.I got mine used for $150 so I felt I could not go wrong.I know alot of people on this site have some insite so lets hear it.Dont flame , I want nelson too.
Old Feb 18, 2005 | 08:54 AM
JERRY2500's Avatar
14 Second Truck Club
Mine worked great, They gave me free custom tunes. But when i got the turbo, they couldn't get the tune right and had it shifting way to hard. I was waiting for something to break everytime it shift and this was just driving normal.
Old Feb 18, 2005 | 09:13 AM
What about removing the TQ managment? The U7193 gives you this ability and was wondering if it is a good thing or not?
Anyone take the TQ Managment off of there truck with a stock transmission?
Old Feb 18, 2005 | 09:32 AM
JRsilverado's Avatar
I am impressed with mine in every aspect except the shifting. I can get it somewhat firm but nothing major. I can't even catch 2nd As a matter of fact, on most roads, I can't even spin on takeoff??? I don't see any difference in theTM with it. I can tell the engine backs off quit a bit right before it shifts. I have heard one guy say that when he sent his back to get updated, they found that it didn't have the TM removed so the reprogrammed it for free.
I will be getting a new PCM to have the TM removed, more power and I just bought some efans. I will be calling Nelson for a harness.
Old Feb 18, 2005 | 11:28 AM
Anyone without TQ Mgmt?
Old Feb 18, 2005 | 11:47 AM
goshawk23's Avatar
Truck addict
you will have to get a custom tune to have tq mgmt taken out. i posted up above that the stock program that comes with the predator only removed a tad tq mgmt on the 2-3 upshift. non no where else.
they just came out with a new version and i don't know if it will take any tq mgmt out either or allow the end user to do such.
i have 80 percent taken out and i can still feel it in there. i have had it autotapped to check for it and they did indeed take about that much out. i also have a relatively stock tranny, just a servo.
Old Feb 18, 2005 | 12:06 PM
When I had my Predator, there wasn't an option of removing the TM. I had the shifts set up for the fastest and firmest possible. For the firmness, I had the all setting on +25% (firmest) and the shift speed was set a -25% (fastest). The shift points settings I based on when I had an HPP and the settings were +3 & 5984 rpms for 1-2 and +11 5948 rpm for 2-3, I left 3-OD stock (based on the 3.73 gears I had). That raised my shifts from 39 mph stock to 42 mph from 1-2 and from 72 mph stock to 83 mph from 2-3 with the HPP. I set the Predator shift point mph and rpm's up similarly, then adjusted form there. Hope this help some.
Jim
Old Feb 18, 2005 | 01:50 PM
According to Diablosport the end user can tune the tq mgmnt. See below:
The Predator allows the end user to adjust the following parameters:
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management ON/OFF adjustment
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Injector Adjustment
Adjust for different injector size
Adjust for long term fuel trims
Catalytic Overtemp protection Adjustement
Disable P0430 and P0430 codes
Adjust COT enable temperature
Multiple Misfire P0300 adjustement
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
EGR disable
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
AIR code disable
Disable P-codes: 0410, 0412 and 0418
Rear 02 disable code
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
