another cam question for 5.7L
Old Jan 20, 2005 | 10:59 PM
haulass350's Avatar
Default another cam question for 5.7L
ok i've called comp a few diff times and spoken with different people and i have two different numbers they recommend, which would be more computer friendly? It WILL get a tune, it wil have 1.6 ratio rollers, and it will be supercharged later this summer but i want my computer to be able to handle it. or are they so close that it wouldnt matter?
here are the numbers and specs
comp 08-304-8
Chevrolet
305ci-350ci
8cyl.
Grind Number CS 266H-R14
Description
------------------------------Intake----Exhaust
Valve Adjustment--------------0--------0
Gross Valve Lift----------------0.500----0.510
Duration At 0.006 Tappet Lift---266------276
Valve Timing At 0.05
-----------------------------Open-----Close
Intake-----------------------(-5)-------35
Exhaust----------------------48-------(-8)
These Specs Are For The Cam Installed At 110 Intake CL
Duration At 0.05-------210-------220
Lobe Lift---------------0.333-----0.34
Lobe Separation 114
comp 08-502-8
Chevrolet
305ci-350ci
8cyl.
Grind Number CS XR269HR-12
Description
-------------------------------Intake-----Exhaust
Valve Adjustment---------------0---------0
Gross Valve Lift-----------------0.495-----0.503
Duration At 0.006 Tappet Lift----269-------276
Valve Timing At 0.006
-------------------------------Open------Close
Intake-------------------------26---------62
Exhaust------------------------74---------22
These Specs Are For The Cam Installed At 108 Intake CL
------------------------------Intake-------Exhaust
Duration At 0.05---------------218---------224
Lobe Lift----------------------0.33---------0.335
Lobe Separation 112
Old Jan 20, 2005 | 11:17 PM
PappyDan's Avatar
Tribe Shaman
how about this instead.
Part Number 54-412-11
Engine 1997-1999 Chevrolet
350ci,
Generation III LS1,
8cyl.
Grind Number LS1 XR265HR-14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.522 0.529
Duration At 0.006 Tappet Lift 265 271
Open Close
Intake 21 64
Exhaust 72 19
These Specs Are For The Cam Installed At 112 Intake CL
Intake Exhaust
Duration At 0.05 212 218
Lobe Lift 0.307 0.311
Lobe Separation 114
Recommended Valve Springs 941-16
and you don't need a tune to run it, but a good tune will bring it out to play.
Old Jan 20, 2005 | 11:24 PM
haulass350's Avatar
350ci,
Generation III LS1,
8cyl.
Description
Intake Exhaust
Open Close
Intake 21 64
Exhaust 72 19
Intake Exhaust
Lobe Separation 114
cause i aint got an ls1
Old Jan 20, 2005 | 11:43 PM
PappyDan's Avatar
Tribe Shaman
it's time to get one
Old Jan 20, 2005 | 11:50 PM
ridnlow's Avatar
Old Jan 20, 2005 | 11:56 PM
That I know off you can't go over a 480 lift on intake or exhaust. The reason it that you will have to machine your heads for the additional lift. Longer pushrods and other stuff to make it work with the vortec heads. I would recommend the CCA-08-302-8 because it has both intake and exhaust lift of 480. This is also a cam for computer controlled applications. Look it up in Jeg's or Summit racing. Its around $250.
With the 1.6 rockers you will put it around 500 lift.
Also it has a basic operation of up to 5200 rpms which is just about all you will be doing once you go supercharged on the vortec 5.7.
Old Jan 21, 2005 | 02:16 AM
haulass350's Avatar
i'm swapping edelbrock e-tec 200's so the heads arent a problem, i jsut dotn relly knwo what the difference is between these cams other then the a little less lift
Old Jan 21, 2005 | 12:54 PM
TieRod's Avatar
I would highly recommend the E-tech 170 over the 200. The 170 out flow the 200 until high lift and have better port velocity. The cam you have listed is not big enough to take advantage of the 200 high lift flow numbers.
Old Jan 21, 2005 | 07:43 PM
litreddevil's Avatar
Banned
We Have A Few Peopple Running The Cran 210/224 Cam In The 96 To 99 Old Body With The Vortex Motors Works Realy Good
USMCvet0311
Aug 1, 2015 07:45 AM
sauldgold
Jul 23, 2015 02:15 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
4B11T
Jul 13, 2015 03:48 PM
